transit connect lowering kits
Postby Mod your Transit » Thu Jun 07, 2012 12:21 am
full front and rear lowering kit for transit connect (all models) with the choice of 40mm or 60mm front springs
there is no cutting or welding needed with this kit,just bolt together.
What you get in the kit
2x front lowering springs. (new)
1x reworked flipped rear axle
4 x rear height adjusting hangers.
the rear axle is rewelded moving the factory brackets and painted,this mean that the axle looks new and factory done
The rear of the van is height adjusting(using our own design) so when you are carrying weight you can raise it up and slam it when showing it.
very simple to fit any d.i.y home mechanic can fit a kit on a sunday.you dont even have to take your rear brakes apart.
This is custom made by us and will be dispatched in a round 5 working day
full kit £375 inc p+p
we also offer a fitting service,drive in drive out.at our company workshop on the herts and essex borders
there is to options £150.00 and you keep your old axle or £100.00 and we keep your old axle
We also have coilovers & rear disc brake kits
40mm
60mm
Mod your Transit
Registered Trader
Registered Trader
