Mk3 Petrol Pinto 2 liter Radiator To Hose
Postby vana mana » Thu Dec 06, 2018 4:11 pm
Hi everyone
It's me again back with another problem
I've just noticed a split on my 89 petrol pinto engined top hose
I've called my local motor factors and they say top and bottom hose are not available
Does anyone have any NOS or very good second hand or help me with any part numbers or alternative ways of solving the problem
This is getting crazy for bits
Seen things in e bay but really not sure what I'm looking at
Thank you in advance
vana mana
Re: Mk3 Petrol Pinto 2 liter Radiator To Hose
Postby Hondekop » Thu Dec 06, 2018 4:36 pm
If you can't find them, you might consider universal radiator hose like these:
https://www.ebay.co.uk/itm/GATES-VULCO- ... rk:19:pf:0
They can be troublesome however in confined spaces. That said, sometimes one can re-route them.
Ciao, Kai
1992 MK4 LWB van, 2.5 TD 101 HP
Hondekop
Postby vana mana » Thu Dec 06, 2018 5:03 pm
Hi
Thanks for the advise
Ihave thought about stuff like this and been looking at car builder solution
I was wondering if mk2 would fit
vana mana
Postby Hondekop » Thu Dec 06, 2018 5:07 pm
Look for Part nr. 61450710 or 6154365, depending on if you have positive carter ventilation or not.
Hondekop
Postby Hondekop » Thu Dec 06, 2018 5:46 pm
Parts catalogue says it's for MK3 exclusively.
Got one here, but if you consider VAT and shipping costs...
https://www.motomobil.com/radiator-hose-upper-ohc-16-20i-46-57kw-not-with-vacuum-cont,3237,61450710-1-h.html
Hondekop
Postby vana mana » Thu Dec 06, 2018 6:09 pm
Is that def mk3
As I just typed transit mk3 radiator top hose in search bar and nothing turned up.?
Confused.?
vana mana
Postby vana mana » Fri Dec 07, 2018 7:11 am
Hondekop
Sorry I just read a better description after clicking on more information
It looks like you are correct
vana mana
Postby Hondekop » Sat Dec 08, 2018 5:15 pm
Next time, you'd better look up the part in the parts manual like:
http://www.catcar.info/ford/?lang=en&l=bWFya2V0PT1ldXJvfHxjYXRfaWQ9PTMyNXx8Y2FiYnI9PUNZfHx0aGs9PTB8fHN0PT0zMHx8c3RzPT17IjIwIjoiRXVyb3BlIiwiMzAiOiJUcmFuc2l0IENZIDE5ODUtMTk5MSJ9
or
https://ford.7zap.com/en/transport/76/6.42397/
At least you'll end up with a (quite) reliable Ford part number then, which you can also use to cross-reference o identical parts from other suppliers.
Ciao, Kai
Hondekop
Postby Keef » Sun Dec 09, 2018 7:22 pm
Keef
Postby Kjeles » Mon Dec 10, 2018 9:13 am
PKWteile has top radiator hoses for Pinto 2.0 L (https://www.pkwteile.de/).
It's called BuyCarParts for the UK (https://www.buycarparts.co.uk/).
Choose your country at the bottom of the home page.
Kjeles
Postby vana mana » Tue Dec 11, 2018 4:06 pm
Hondekop wrote:Next time, you'd better look up the part in the parts manual like:
or
Ciao, Kai
Thank you
I appreciate your help
vana mana
Postby vana mana » Tue Dec 11, 2018 4:23 pm
Kjeles wrote:PKWteile has top radiator hoses for Pinto 2.0 L (https://www.pkwteile.de/).
Thank you but I'm struggling to find the hose on here or a picture
Do you know the direct link
It's appreciatef
vana mana
Postby Hondekop » Wed Dec 12, 2018 9:18 am
[url]https://www.buycarparts.co.uk/ford/transit-bus-t/8722/10200/radiator-hoses?sort_categories[]=546[/url]
The only ones they've got. Looks these are for positive carter ventilation. If you haven't got that, you'll have to block the side branches off.
Hondekop
Postby vana mana » Wed Dec 12, 2018 6:47 pm
Hondekop wrote:[url]https://www.buycarparts.co.uk/ford/transit-bus-t/8722/10200/radiator-hoses?sort_categories[]=546[/url]
Both out of stock, thank you for trying though
vana mana
