Mk5 bosch pump wont turn
Postby powercrazymark » Sun Sep 13, 2020 1:15 pm
I acquired a bosch 145 pump yesterday and it wont turn by hand. Is this right and does it take some force to turn it or do I need to strip this pump, fix and rebuild?
powercrazymark
Re: Mk5 bosch pump wont turn
Postby V184 » Sun Sep 13, 2020 9:03 pm
yes they are tight to turn
V184
Location: You're right, V184 is an arsehole with a chip on his shoulder........
Postby powercrazymark » Mon Sep 14, 2020 8:47 am
Ok so I can turn it with a 22mm spanner. But it will only turn anticlockwise and it jumps around in sections rather than on fluid motion is this right?
powercrazymark
Postby MinorMatt » Mon Sep 14, 2020 8:48 am
Yes that's right
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Chug » Mon Sep 14, 2020 9:54 pm
It turns clockwise looking from the 22mm nut end, but it should turn in either direction and in four equal turns per one complete shaft revolution, each quarter turn moves over a hump in the camplate, which has four cams, or humps, one for each plunger/injection stroke.
Chug
Postby powercrazymark » Tue Sep 15, 2020 9:32 pm
This seems to be the case chuggy however it just gets jammed if I try and turn it clockwise looking directly at the 22mm but anticlockwise seems fine.
powercrazymark
Postby Chug » Wed Sep 16, 2020 8:54 am
Sounds like there is something amiss in the pump, removing the top cover may let you see what is going on.
Chug
Postby powercrazymark » Wed Sep 16, 2020 3:47 pm
Is that the 4 Allen bolts?
powercrazymark
Postby Chug » Wed Sep 16, 2020 8:24 pm
Are you clamping the pump in a vice when you try to turn it?
yes the four allen bolts, the throttle idle adjustment screws need removing to get to rear right one, and with the throttle arm make sure to scribe a line to mark the postion to make sure it goes back in the correct position.
bosch stipdown vid look here https://www.youtube.com/watch?v=_01gEg2ZMwg
Chug
Postby powercrazymark » Sun Sep 20, 2020 7:58 am
So I cleared the bench ready to stip the pump and just before I did i tried on last time at turning it clockwise and it turned. Now it turns both ways, but the other day it was definatly jammed clockwise. This pump has been sitting for a while so maybe it has just freed itself up by my tuning it a couple of times, or is it still worth the strip down?
powercrazymark
Postby Chug » Mon Sep 21, 2020 9:01 am
It might be ok, it might not, it's your call as to whether you just fit it and hope for the best, or have the confidence and knowledge to strip and rebuild the pump.
Chug
croncroncron
