by MinorMatt » Thu May 06, 2021 3:51 pm
Hazard lights should work regardless off whether the ign is on/connected - but it looks like the indicator switch isn't connected? That would stop them working.
Check to see if the ign relay is in the fusebox, its a black one (key on the cover). Also check the fuses between the battery and the wing.
www.facebook.com/transitionclassicsLucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
