Wiring locations ignition
Postby gsc1ugs » Thu May 06, 2021 3:23 pm
Can anyone tell me where the red and black with the words kopex ho to in relation to the ignition please? Bought stolen with wires ripped out. Please see attachments, this is 1998 smiley face banana diesel
gsc1ugs
Re: Wiring locations ignition
Postby MinorMatt » Thu May 06, 2021 3:35 pm
Thats not factory wiring... so sorry don't know
What have you still got?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby gsc1ugs » Thu May 06, 2021 3:41 pm
I have all the ignition and switch new plugged in see pic these two are quite thick so im assuming they came from near starter or switch. There is no hazards lights or ignition coming on
gsc1ugs
Postby gsc1ugs » Thu May 06, 2021 3:51 pm
Also those two leads, black as solder on red looks pulled out, its not come from behind fuse box ive looked and theres no place for it
gsc1ugs
Postby MinorMatt » Thu May 06, 2021 3:51 pm
Hazard lights should work regardless off whether the ign is on/connected - but it looks like the indicator switch isn't connected? That would stop them working.
Check to see if the ign relay is in the fusebox, its a black one (key on the cover). Also check the fuses between the battery and the wing.
93 L GL Minibus
Postby gsc1ugs » Thu May 06, 2021 4:06 pm
Is this the fuse box next to steering under dash?
gsc1ugs
Postby gsc1ugs » Fri May 07, 2021 7:59 am
Is the ignition relay any of these see pic? Also is there a master fuse that controls everything? I had this witha twingo stolen they had robbed the main fuse which even turned off the hazards
gsc1ugs
Postby MinorMatt » Fri May 07, 2021 8:11 am
Yes its the black one top left
The master fuses are the ones between the battery and the wing.
If you haven't got both sets of column switches the hazards won't work anyway
93 L GL Minibus
Postby gsc1ugs » Fri May 07, 2021 9:09 am
Both are connected hazards still not working, do you know if this cut red is normal? Still trying to find place for the thick red and black
gsc1ugs
Postby MinorMatt » Fri May 07, 2021 9:35 am
Thats the ign switch cable?
No its not normal for it to be cut - and would explain why you have no ignition circuit. Unwrap the shrouding around the rest of the cables attached to it and see if you can see whats left of the cable. I don't know off hand where that cable should connect
As said that black and red has been added by someone - I would be following the wires to see where it goes
93 L GL Minibus
Postby gsc1ugs » Fri May 07, 2021 9:54 am
After uncovering i found another and both dont seem to be goin anywhere
gsc1ugs
Postby gsc1ugs » Fri May 07, 2021 11:47 am
Those two snipped wires trace back going to these on the ignition switch see pic, still no power or hazards is there a fuse?
gsc1ugs
Postby gsc1ugs » Fri May 07, 2021 12:08 pm
Are these missing anything next to battery?
gsc1ugs
Postby MinorMatt » Fri May 07, 2021 9:18 pm
2 fuses is normal
93 L GL Minibus
Postby gsc1ugs » Sat May 08, 2021 7:54 am
Well everything is back together even wiring and still no power, is there anything else to look at? Anything missing in this fuse box
gsc1ugs
