Mild performance increase possible?
Postby HairyFool » Thu May 13, 2021 1:10 pm
I have a 1998 2.5TD Auto, Epic Pump. Damned great Fibreglass box fixed to it (AKA AS Motorhome) It has only done 23,000 miles. As far as I know everything is absolutely bog standard apart from the MH mods
Two issues. Any options to increase performance, it doesn't take much of a hill to pull it down? It happy to cruise at 60 on the flat and need no more than that. If nothing else the wind noise drowns out the radio :roll:
Nothing too heavy to protect the box.
When it does slow the box is reluctant to kick down.
HairyFool
Re: Mild performance increase possible?
Postby Chug » Thu May 13, 2021 1:48 pm
You cannot do anything with the Epic injection pump, and being an auto means you would have to change the gearbox to fit a Bosch injection pump, but when was the fuel filter last changed? it might just be fuel starvation on high demand like hills.
Chug
Postby MinorMatt » Thu May 13, 2021 2:44 pm
The only thing you can do is to fit 100PS injectors to your engine - and make sure its serviced properly (i.e. valve clearances, cambt timing etc
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby HairyFool » Thu May 13, 2021 4:55 pm
Sadly both confirm my lack of results for finding anything in the way of options.
Curious about the need to change gearbox with the fitting of a Bosch unit?
Hopefully doing the cam belt in the next few weeks prior to putting it on the road, I will look at the filter at the same time.
HairyFool
Postby MinorMatt » Thu May 13, 2021 5:32 pm
The auto gearbox is controlled by the ECU.
If you go to bosch the ECU gets confused, and you lose top gear and get extremely harsh banging gearchanges
93 L GL Minibus
Users browsing this forum: dumyat
