****NOW BOOKED FOR 2021**** Transitmania 12 @Santa Pod 16th to 18th July 2021 ****ALL DETAILS HERE****
2.5 di just cut out no restart?
Postby Mattyone » Fri Jun 11, 2021 12:24 am
Hi everyone, got a 2.5 di in my boat and been running fine until today after running for 3 to 4 hours on and off the engine just cut out as if someone turned the ignition off. Tried to restart but nothing, turns over fine but wont fire up. any idea`s please
Mattyone
Re: 2.5 di just cut out no restart?
Postby Keef » Fri Jun 11, 2021 1:23 am
Check the cambelt hasn't stripped or snapped.
Keef
Postby Altransit » Fri Jun 11, 2021 7:31 am
Keef wrote:Check the cambelt hasn't stripped or snapped.
Likely stripped around the bottom pulley where there are fewer teeth, it's about the only reason that a Di just randomly stops :(
Postby Mattyone » Fri Jun 11, 2021 7:39 am
Sorry because of it been late when we finished and a bit kernackered forgot to mention we was having trouble with the ignition switch, when we turned the key to start no issues, but when we turned the key to stop the engine there was a delay before it stopped of about 5 seconds and during the day it got progressively worse to extent where it took about a min or so before it actually stopped, could that be the cause.
Mattyone
Postby dumper » Fri Jun 11, 2021 8:00 am
Possible the injection pump is breaking up inside and jamming the stop open ( had loads of pump failures when we went to low sulphur diesel first the stop started jamming and not long after need new pump )and now possibly stuck closed or it’s just packed up .with ignition switch on try unplugging the feed wire on and off and listen if you can hear it click
Postby bambi mk 1 » Fri Jun 11, 2021 8:04 am
dumper wrote:Possible the injection pump is breaking up inside and jamming the stop open ( had loads of pump failures when we went to low sulphur diesel first the stop started jamming and not long after need new pump )and now possibly stuck closed or it’s just packed up .with ignition switch on try unplugging the feed wire on and off and listen if you can hear it click
X2 remove the stop solenoid and check for filings stuck to the plunger :idea:
bambi mk 1
Postby Altransit » Fri Jun 11, 2021 8:18 am
It's always possible, it's only about £20 for a new switch, and a few minutes to fit it :)
Postby gotgcoalman » Fri Jun 11, 2021 8:04 pm
Check for voltage to the solenoid on the pump when the ignition is on and when off.
Might be a bad wire/connection.
Sent from my Plus E using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby Mattyone » Sun Jun 13, 2021 11:27 am
The cam belt had stripped teeth and bent two push rods, the rocker seems fine
Mattyone
Postby Mattyone » Sun Jun 13, 2021 11:29 am
Exactly what you said stripped the teeth round the bottom pully, bent two push rods, is there a reason for stripping teeth there, is it like you said few teeth on the bottom pully.
Mattyone
Postby Mattyone » Sun Jun 13, 2021 11:31 am
Altransit wrote:It's always possible, it's only about £20 for a new switch, and a few minutes to fit it :)
Changed the switch but unfortunately it was the timing belt switch thanks for your input
Mattyone
Postby dumper » Sun Jun 13, 2021 1:47 pm
Yes belt passed it service miles or oil contamination just fit a new belt and tensioner and time it up fit new push rods or straighten the old ones should be ok not often a di does more damage.
Postby Mattyone » Sun Jun 13, 2021 7:31 pm
I have a photo same engine layout as mine, when I took the belt off and the rocker off the pully in the photo right side spins freely by hand is this correct
Mattyone
Postby Keef » Sun Jun 13, 2021 10:58 pm
That pulley is for the camshaft so If you've taken the rocker shaft off then it probably will spin fairly freely.
There's a guide here viewtopic.php?f=18&t=56801
Keef
Postby Mattyone » Mon Jun 14, 2021 12:02 am
Keef wrote:That pulley is for the camshaft so If you've taken the rocker shaft off then it probably will spin fairly freely.
I have taken it off but not an expert so just checking thank you
Mattyone
