****NOW BOOKED FOR 2022**** Transitmania 13 @Santa Pod 20th 22nd May 2022 ****ALL DETAILS HERE****
Immobiliser problem 2000 Smiley 4x4
Postby mtbrik » Wed Oct 13, 2021 2:53 pm
Immobiliser issue help/advice required.
I have a 2000 Smiley ex fire service County 2.5td.
I’d just replaced the starter motor and had the van running sweetly for one journey and then it just cut out.
The dash lights are lit but no cranking and no solenoid clicking from anywhere.
The van is now at my local garage, and he’s checked the keys and all the earths, fuses and relays but to no avail.
The flashing security light is no longer flashing, if that gives any clue as to the cause.
Where do I go from here?
I am based near Dumfries and the experienced auto electrician that might have known his way around an old van has retired and none of the younger guys want anything to do with it.
mtbrik
Re: Immobiliser problem 2000 Smiley 4x4
Postby Altransit » Wed Oct 13, 2021 3:10 pm
The fuse box down by your right knee (sitting in the drivers seat), take the cover off and check the two fuses on the bottom row RH side (I think they're F32 & F33, 5 amp) :idea:
Postby MinorMatt » Wed Oct 13, 2021 3:21 pm
My diagnosis too Al,
Fuses 32 and 33 are in the fuse box for a reason, but have no markings :wink:
If thats not the cause its worth just double checking the PATS module hasn't become disturbed - its under the passenger side dash cubby.
Shame your not local - I would be able to sort it quickly!
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Altransit » Wed Oct 13, 2021 3:27 pm
MinorMatt wrote:My diagnosis too Al,
In mine it was a damaged wire inside the RIM module on the back of the pump. From time to time it would short out and blow those fuses, but it could equally be one of the external wires.
Postby MinorMatt » Wed Oct 13, 2021 3:38 pm
It won't be the RIM on a TD ;) But thats a commonish problem on non turbos
93 L GL Minibus
Postby V184 » Wed Oct 13, 2021 5:57 pm
mtbrik wrote:Immobiliser issue help/advice required.
Battery leads ok ?
V184
Postby mtbrik » Wed Oct 13, 2021 6:06 pm
Yup battery leads are good and tight.
I’ll check the fuses as soon as I can get to it, its a bit of a pedal away :-)
mtbrik
Postby V184 » Wed Oct 13, 2021 7:13 pm
mtbrik wrote:Yup battery leads are good and tight.
try running jump lead as an earth
V184
Postby mtbrik » Wed Oct 13, 2021 8:59 pm
Hi Matt
Is the PATs module the black box behind the ECU?
Rik
mtbrik
Postby MinorMatt » Wed Oct 13, 2021 9:15 pm
yeah underneath ecu
93 L GL Minibus
Postby mtbrik » Wed Oct 13, 2021 11:18 pm
And I’d be looking for a poor connection or could it be goosed?
mtbrik
Postby MinorMatt » Thu Oct 14, 2021 8:25 am
If its got water in it could be goosed, its not *that* unusual for water to get in....
If you get a lever and push it towards the center of the van it will come loose and you may be able to wiggle it out
I think its probably your fuses though
93 L GL Minibus
Postby haig007 » Thu Oct 21, 2021 11:10 pm
Have the same problem led flashing but dont know what it is saying have ecu tested key tested but still not starting :roll: any help
haig007
cron
