Hi all,
I've been changing the brake shoes today on my twin rear wheel transit mk3. The lug nuts on both sides were so insanely tight, I needed a breaker bar with a 3 meter steel tube on the handle, and i still needed to put all my force into the bar to get them to crack. The wheels were fitted by a garage that does trucks and I watched them use a massive air gun to tighten them up.
So my question is should they be that tight? And now i've put the wheels back on I've tightened them with my makita impact wrench and then checked them with the breaker bar and I can't get them any tighter. Is that sufficient? They are no where near as tight as they were before.
