Axle hub nut stockists
Postby protechdm » Mon Oct 10, 2022 3:06 pm
Could anybody point me in the direction of new rear axle hub nuts? The vehicle is a Ford P100 but I was informed this variety was also fitted to a Mk3 Transit. The axle diameter is 43mm and the socket size is 50mm, it is the bi-hex type. Cheers!
protechdm
Re: Axle hub nut stockists
Postby meerkatmag » Mon Oct 10, 2022 5:35 pm
Transit centre have a good selection: https://www.transitcenter.uk/advanced_s ... nut&mark=0
1988 transit MK3 2.5di na
meerkatmag
Postby protechdm » Mon Oct 10, 2022 7:56 pm
Yes dropped them a message earlier. They are in Poland? See, I'm not even 100% sure if they will actually fit, just everything points to them being the same apart from both sides on the P100 being RH threaded. Failing that, I guess it will be a case of a machine shop being able to make one up for me.
protechdm
Postby meerkatmag » Mon Oct 10, 2022 9:46 pm
protechdm wrote:Yes dropped them a message earlier. They are in Poland? See, I'm not even 100% sure if they will actually fit, just everything points to them being the same apart from both sides on the P100 being RH threaded. Failing that, I guess it will be a case of a machine shop being able to make one up for me.
Yeah it's relatively expensive to have them shipped and I don't know how easy it would be to return items. If it helps my MK3 has 65mm normal hub nuts (not bi hex) and both sides RH thread I think. I'm not sure if any of the mk3s have bi-hex to be honest. I've never heard of a 50mm hub nut fitting a transit either. People seem to have either 65mm or 56mm.
Is the p100 front wheel drive? Mk3 transits are RWD. Sounds to me like maybe they don't share the same parts. Hopefully someone else will chime in and confirm or disagree!
meerkatmag
Postby ned » Mon Oct 10, 2022 10:09 pm
The p100 was either cortina based or sierra based iirc so both rwd, have you tried looking up a hub nut for either one of them?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby meerkatmag » Mon Oct 10, 2022 10:17 pm
Got curious and did some digging, perhaps these part numbers, from a 80-120 transit mk3.
A quick google search came up with this:https://www.ebay.com/itm/275312090298
Which appear to be the right size and shape...
meerkatmag
Postby protechdm » Tue Oct 11, 2022 9:40 am
Yep those part numbers are exactly the ones I have written down here after digging. They cross reference to ABS910761 & ABS910772. Fitted to the Mk3 between '89 & '91.
protechdm
Postby MinorMatt » Tue Oct 11, 2022 11:06 am
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby protechdm » Tue Oct 11, 2022 8:45 pm
Can confirm, part number 5021935 / ABS 910761 fit the axle. The only issue is that the collar on the hub nut cannot be staked into the axle stub as it does on the P100.
protechdm
Postby Chug » Tue Oct 11, 2022 11:04 pm
so, the ones with the 5021935 / 910761 part numbers linked ads say LH thread, and you said your P100 ones were RH thread, and now you say they fit?
are the ads wrong, are yours LH thread, have I got it all wrong, I'm confused :?: :lol:
Chug
Postby protechdm » Tue Oct 11, 2022 11:30 pm
Guess the ad is incorrect. Both sides on the P100 are RH thread for sure.
protechdm
Postby protechdm » Mon Oct 17, 2022 7:14 pm
I guess my question is, these axle nuts which do not have a collar, I've torqued them up to 250nm. But there is no collar to stake them into the axle stub. So, for the transit owners who have fitted them, how do you stop them potentially coming loose?
protechdm
Postby V184 » Mon Oct 17, 2022 7:37 pm
protechdm wrote:I guess my question is, these axle nuts which do not have a collar, I've torqued them up to 250nm. But there is no collar to stake them into the axle stub. So, for the transit owners who have fitted them, how do you stop them potentially coming loose?
Arent they made like a lock nut ?
V184
Postby protechdm » Thu Oct 20, 2022 8:38 pm
Not sure. In fact lock nuts seem to come in various guises these days. They must do something i.e. stretch threads because they're a "one shot". Certainly no nylon collar on the internal.
protechdm
