1998 Transit MoHo Engine Issues
Postby pudska » Sun Sep 04, 2022 11:40 am
New member and in need of help please.
I have a 1998 2.5TD Transit Motorhome (Chassis No. WF0AXXGBVAVR68050) and The electric part of the EGR valve has failed so I'm searching for a replacement (new or used )the original part No. is – 7095098 and the manufacturing No. is - 95VB-9E882-AA Does anyone have one or know where I can get one please? even a pattern part will do. I did try EGR valve part No. 88034 looks exactly the same but the fixing bolts don't match up.
pudska
Re: 1998 Transit MoHo Engine Issues
Postby MinorMatt » Mon Sep 05, 2022 8:13 am
Just blank the EGR off, it won't cause limp mode - just put the engine management light on for 5 seconds on start up
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby pudska » Mon Sep 05, 2022 12:26 pm
Thank MinorMatt
Thanks for your reply, Will that have an effect on the omission's?
pudska
Postby MinorMatt » Mon Sep 05, 2022 1:33 pm
It will marginally increase nitrous oxide emissions, but will reduce particulate/smoke emission.
Particulate/Smoke emissions are what are measured at MOT, so it will be better from MOT perspective
2 x 2006 Mk7s
Postby pudska » Mon Sep 05, 2022 1:43 pm
Excellent Minormatt
Thanks again for your reply and knowledge :D
pudska
Postby pudska » Fri Oct 21, 2022 6:12 am
I have fitted the blanking plate and it has made a difference but still not 100% its limiting at 65 MPH @2750 RPM and that was downhill!! any up hills I face, I'm shifting down the gears :( Fed up with it now, can anyone help me shed some light on it?
Thanks.
pudska
Postby andypdq » Sat Oct 22, 2022 3:49 pm
Throw the Lucas Epic and fit a mechanical injector pump. Simple.
The first Mk 6 mechanical TDDI, giving electronics the finger, since April 2013
Perfection is reached, not when there's nothing left to add, but when there's nothing left to remove.
YouTube https://www.youtube.com/channel/UCNypVH ... dKUN5eJDyQ
andypdq
