2.5 Di 70ps vs 80ps
2.5 Di 70ps vs 80ps
Postby Transit_Nugget1989 » Thu Jun 01, 2023 9:47 am
Hi, what is difference between 2.5 Di 51kw and 59 kw non turbo motors. I would like to upgrade my 51kw to 59 kw. Thanks.
Transit_Nugget1989
Re: 2.5 Di 70ps vs 80ps
Postby dumper » Thu Jun 01, 2023 10:46 am
Is the lower one a non banana the early engine.
Postby Transit_Nugget1989 » Thu Jun 01, 2023 11:13 am
dumper wrote:Is the lower one a non banana the early engine.
yes, i know but i want to know difference. What i need to upgrade.
Transit_Nugget1989
Postby dumper » Thu Jun 01, 2023 1:31 pm
I would think it’s probably injectors and adjust the pump settings I think I’ve read somewhere that the banana manifold is to improve the torque
Postby Keef » Thu Jun 01, 2023 9:57 pm
80ps is the earlier version. It was non banana inlet manifold and had a two into one exhaust.
70ps is the later non banana. If I remember correctly it was all about better emissions and bugger the performance. Was the first with an egr I think.
They probably had different injectors and minor pump differences.
I've driven both and there isn't much difference. You'd probably get the same performance if you wound the pump up a bit on a 70ps
Keef
Postby V184 » Fri Jun 02, 2023 8:39 pm
Keef wrote:80ps is the earlier version. It was non banana inlet manifold and had a two into one exhaust.
The 80ps did have the banana inlet it was fitted in the 92 on,later changed to the 76ps in the "smiley front " 95 model
V184
