What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby gotgcoalman » Wed Jun 07, 2023 5:37 pm
Here's another thing.
Load sensing valve spring has left the building.
It has gone/vanished done a runner.
The valve still appears to be free.
Are the springs available OR do I have to buy a new valve with the accompanying spring?
Vroom vroom.
My van looks like a dog pissing up a lamppost.
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby Chug » Thu Jun 08, 2023 12:42 am
if you fit both lower leaves will the u bolts be long enough?
I don't see a part number for the spring only so it looks like its a new load sensing valvehttps://www.ebay.co.uk/itm/323815779694
Chug
Postby gotgcoalman » Thu Jun 08, 2023 8:21 am
Cheers for confirming my worst fears.
73 turnips for a spring
Although a shiny valve is thrown in for free
U bolts would accommodate the extra leaf if fitted
Vroom vroom
gotgcoalman
Postby gotgcoalman » Thu Jun 08, 2023 3:34 pm
Frankenspring
U bolts seem ok.
You only need them on the first couple threads don't you
Re the load valve spring.
It appears you can get them for hairdressers vans.
Is it an option to try or would it be £20 thrown in the air?
gotgcoalman
Postby gotgcoalman » Thu Jun 08, 2023 3:38 pm
Made the centre pin out of an M10 bolt.
Rounded the head to fit the locating hole on the axle in true bjt style
gotgcoalman
Postby MinorMatt » Thu Jun 08, 2023 3:53 pm
Spring is not available seperately...
but here is a half price option.
Some bodgery would be required to swap the spring over. Also check before buying a valve whether you need the 2 port or 4 port option
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby gotgcoalman » Thu Jun 08, 2023 4:32 pm
Deffo the 2 pipe version.
Bodgery is my middle name
I'd warmed up and rebent the old one several times when the hook bit had snapped off before it totally vanished this time.
gotgcoalman
Postby gotgcoalman » Fri Jun 09, 2023 5:02 pm
Arghhhhhh stripped one of the U bolts.
Don't know why I had a pair of verrrrrrry long ones, although had to cut an inch off it as my deep socket wasn't deep enough
Seemed a false economy not taking the drum off while I was there.
Then remembered I'd renewed the shoes and springs last year,thanks to Matt
Adjusted the shoes 1 click and the bloody drum was binding so badly (foooookme the self adjusters must be working)
No lip on the drum btw.
Vroom vroom chaps.
Oh something in the back of my mind tells me not to fully tighten the Ubolts until the wheels are on and it's on the floor.
Might be me having a 'senior moment" though.
Other side to follow.
Let's see if it sits any better when finished
gotgcoalman
Postby gotgcoalman » Sat Jun 10, 2023 6:05 pm
Frankenspring MK2 is in the other side now.
Srripped the threads on both when tighting this time
Ordered replacements
Sticking a extra leaf in,albeit the bottom one has given 2" lift on the back end.
I was expecting the depth of the leaf which most certainly isn't 2".
gotgcoalman
Postby gotgcoalman » Wed Jun 14, 2023 4:38 pm
Whooooooooo.
It's out
Took the front bush insert with it though
I shall remove said sleeve and re fix it with a tigerseal type substance.
Let the bashing commence
gotgcoalman
Postby gotgcoalman » Thu Jun 15, 2023 3:31 pm
Right chaps.
After using heat/plusgas more heat, soaking in plusgas overnight.
Stillsons with a 3' pipe and using the rattlegun on the bolt.
Haven't managed to get the bush sleeve off the threads or indeed get the bolt to spin within the wishbone.
Anyone got the part numbers for the bolt and front bush.
Brute force isn't working in this case
Bloody Ford
gotgcoalman
Postby MinorMatt » Thu Jun 15, 2023 4:17 pm
I've got new (pattern and genuine) bushes and I'm sure I can find you a used bolt too
93 L GL Minibus
Postby gotgcoalman » Thu Jun 15, 2023 4:23 pm
Nice one "old chap" have a good rummage for me, it'll be much appreciated
I have your details for transferring the relevant amount of birthday cake in recompense.
Vroom vroom,I have a 3 wheeler mk5
gotgcoalman
Postby MinorMatt » Thu Jun 15, 2023 4:25 pm
I guess you need them fairly quickly? I should be able to post tomorrow afternoon.
One bush or 2? :lol:
93 L GL Minibus
Postby gotgcoalman » Thu Jun 15, 2023 4:41 pm
The replacement wishbone came with the back one fitted.
The destroyed one is the subframe one the front bolt goes through.
Much ass grassiass as Ned would probably say
gotgcoalman
