Sorry – this is going to be a bit long!
Our Transit is a 1998 AutoSleeper Duetto motorhome with 98,000 miles recorded. We are currently in Italy, and until 10 days ago, it has run flawlessly. While we were sitting with the engine idling, the red light came on and the engine became (even) noisier than usual. I couldn’t get rid of the problem and we drove on to a camping ground. The van lacked power but would manage 50mph OK. I naturally thought that the Epic fuel pump had failed. I started and stopped it a couple of times on the way, but the problem persisted. When I next tried to start it, the starter solenoid chattered. Low voltage. I found that one of the battery terminals was quite loose. I cleaned and retightened them, and the problem had gone. No problem next day, but the morning after that, it happened again. After a few restarts, it went away for the day. That has been the pattern ever since. It starts fine, runs for a few seconds, and the light comes on. If I drive off, it’s sluggish and noisy. But, after a few minutes’ running, a restart, or maybe two, will see it run perfectly for some hours. Sometimes it won’t happen again until next morning, but other days, it will play up a few times, but always come right with a stop and restart or two or three. I’ve tried disconnecting the battery for a minute or so, and also stalling it to stop it, but the result is the same as using the key.
The only “pattern” I’ve worked out is that once it has come right, it doesn’t seem to fail while driving at open road speeds. Most failures happen when driving very slowly, say in traffic or in a camping ground. The engine starts very well, and stops as soon as the key is turned off, so the fuel shut-off system seems to be OK, and as it runs perfectly when the fault has disappeared, it appears that there is unlikely to be a najor mechanical fault.
As it runs so well when the fault has gone, I feel it’s likely that we’ll get back to the UK OK even if the problem persists. I doubt that I could find anyone in Italy who could read the fault codes, and there is the language barrier. I wonder if the low battery voltage from the loose terminal could have damaged something electrical. I presume it would have generated fault codes and would have sent it into limp mode on that first occasion. But I am at a loss as to why the problem keeps coming back.
I would appreciate any comments and advice.
Thanks.
Alistair
