The smooth shaft, are you sure that's not the inside of a broken off grease nipple? What you might had pushed in may had been the spring. I would had thought there would had been some trace of the thread there unless you'd drilled it. If I remember rightly it's 1/4" UNF or metricmeerkatmag wrote:I must have completely knacked the threads then as it just looks like a smooth shaft. I guess I'll have to re tap them? I hope that bit of metal doesn't destroy the inside of the uj when it's spinning.
Oh shitemeerkatmag wrote: and the material is so tough the tap broke.
meerkatmag wrote:I tried a stud remover on the broken nipple and it just pushes it inside and it disappeared into the uj! It doesn't look like a thread? It looks more like a push fit. Are you sure these nipples are threaded?
