I've recently fitted a turbo to my van and generally it's been driving nicely since. But the other day I had an intercooler hose pop off at full boost and while putting it back together (tighter this time) I noticed there's a fair amount of oil inside the pipes. I took a few other hoses apart to check and really the whole system from turbo outlet into the intercooler is laced with oil, in a few places it has pooled a bit. Is this normal? There is a PCV system attached before the turbo inlet so I guess it could be all from that. It does seem a lot considering I've only driven it a few hundred miles since fitting the turbo.
I did have some issues with the turbo oil drain pipe, as it's so short the AN hoses kept kinking so I was forever making new ones. Finally got it to work with a 16mm rubber hose and barb fittings, rather than a full AN10 hydraulic line. I did drive it a bit with some of the kinked hoses, now I'm worried that this restriction could have messed up the seals in the turbo?
How much oil would you expect to see in the turbo hoses? Is some oil normal? Does it sound like something is wrong?
