Mk5 passenger airbag deactivate
Postby Klmi » Wed Apr 03, 2024 10:35 pm
Hi there,
I need to transport my newborn in the front row of my Mk5. Unfortunately I can't turnoff the passenger airbag as there is no way build in.
Is there a way to deactive it completely or some spare parts to add as module to turn it off by key?
Is there any other facing this issue and might already have a solution to the problem?
As far as I my local dealers told me there is no approved solution from Ford but anyway, maybe there is a third party component which can be used as a substitute and later the modification can be added to the vehicle papers by the German TÜV. I found a couple of alternatives but none of them work in Ford...
Looking forward to any suggestions you may come up with :)
Klmi
Re: Mk5 passenger airbag deactivate
Postby MinorMatt » Wed Apr 10, 2024 11:17 am
Passenger airbag was an option - so unplug and fit an airbag module from one without passenger airbag... or use a resistor and capacitor in to tricking the system in to thinking its working.
Then remove airbag and fit the "blank" that fits in its place?
Or.... put a suitable switch switch in to disconnect the airbag and connect the resistor/capacitor instead if you need it disabled?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
