Bosch VE Fuel Pump Minor Leak from Underside Transit MK5 Di
Postby Timelourd » Mon Mar 09, 2020 9:16 pm
Pressure from a knackered injector caused a leaky old gasket in the pump, which then caused the bleed nipple/pressure relief valve at the side of the Bosch VE pump to spit. I plugged the pressure relief valve with some molten steel and replaced the knackered injector.
Now the final leak is just a tiny bit of fuel coming from the underside of the pump. Not sure if this is easy to replace, or if I'll fudge it up.
Anyone got any experience with this?
I'll update this post with pictures in a bit.
1996 2.5di MK5 Banana Engine
Timelourd
Re: Bosch VE Fuel Pump Minor Leak from Underside Transit MK5
Postby Chug » Tue Mar 10, 2020 2:56 pm
There are only really a few places it can leak from, inlet or return pipes/connections, injector pipes, front shaft seal, top cover o ring, throttle shaft o ring, or the distributor head o ring.
Clean any leaked fuel from the pump and make sure its dry then stick a few paper towels around the pump body and start the engine and look for damp spots appearing on the paper towels.
Chug
Postby Timelourd » Thu Mar 12, 2020 6:42 pm
Great idea Chuggy. I guess I can send back that UV fuel dye.
Timelourd
Postby Timelourd » Sun May 08, 2022 1:46 pm
Turns out one of my injectors was busted. I replaced it and the leak stopped.
Timelourd
Postby Peterr » Thu Apr 23, 2026 11:57 am
Looks like I may have a similar issue. I replaced the Epic with a Bosch but it won’t start. Fuel spills out the bleed nipple when trying to start. Injectors were working fine with the leaking Epic pump. This has me stumped.
Keep on Transiting !
Peterr
Postby Peterr » Fri Apr 24, 2026 9:25 am
Just to be sure I rechecked the pipes. The original Lucas pump has this order:
Pump cylinder order:
from back of pump:
1…….3
2…….4
Now according to this drawing the Bosch has the same order:
Peterr
