What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby gotgcoalman » Sat Apr 18, 2026 5:30 pm
Some bloke on tiktok said if I run my air filter under the shower for an hour and then put it in the air fryer at 180 degrees for 15 minutes it would be as good as new.
Answers on a postcard
Too bloody quiet :shock:
gotgcoalman
Postby Altransit » Sat Apr 18, 2026 6:14 pm
gotgcoalman wrote:Some bloke on tiktok said if I run my air filter under the shower for an hour and then put it in the air fryer at 180 degrees for 15 minutes it would be as good as new.
That only works on Mk3's :roll: :lol:
Postby dumper » Sat Apr 18, 2026 6:37 pm
Cost you more in electricity then buying a new one
Postby gotgcoalman » Sat Apr 18, 2026 7:12 pm
Lolzzzzz chaps.
A fresh one has been ordered.
£4.95 delivered by Tpuk.
So......
Does anyone want to buy a "slightly used" Mk5 air filter?
gotgcoalman
Postby gotgcoalman » Thu Jul 30, 2026 5:37 pm
Changed "grumbly prop bearing" today and noticed a suspicious bit of floor whilst underneath.
So like a total dick I poked it.
It produced a hole under the passenger seat.
Ford did away with the tilting seat arrangement,so I had to spanner the sh*t out of it
Tbh it's a wonder the seat hadn't fallen through.
Most of the rot was hidden by the tank,box section and the heat shield underneath.
I do like a challenge
gotgcoalman
Postby gotgcoalman » Fri Aug 07, 2026 4:37 pm
So the mk5........
When someone says "it's a rust bucket"
I can reply "no it's a van,this is a rust bucket"
Bring back + earthed vehicles
gotgcoalman
Postby ned » Fri Aug 07, 2026 5:22 pm
gotgcoalman wrote:So the mk5........
That’s not that much rust I’ll swap you for my pile of rust
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby gotgcoalman » Fri Aug 07, 2026 6:14 pm
Fook ned your newer motor is composting quicker than mine
gotgcoalman
Postby ned » Fri Aug 07, 2026 6:37 pm
:lol: :lol: That’s not that was just the sill and step on the passenger side
Rust is lighter then carbon fibre, I like to say it’s not rusting its weight saving
ned
Postby Peterr » Sat Aug 08, 2026 6:06 am
Rusting from within the metal seems to be a chronic disease with some Transits. Apparently Ford used batches of poorly recycled metal that wasn’t properly processed which contained micro bubbles of rust within the sheet metal. So even after cleaning and painting the rust will appear again from underneath.
I use Owatrol oil to treat it. It’s got good penetration and works very well on hard to reach areas.
Keep on Transiting !
Peterr
Postby cherniy_chack » Tue Aug 11, 2026 4:43 pm
After replacing the engine with a rebuilt one, I'd only driven 1,000 kilometers when I noticed vibration in the driveshaft. It turned out that all six CV joint mounting bolts on the driveshaft had come loose.
I slightly moved the hanger bearing and tightened the bolts with an impact wrench.
While driving on a bad road, I damaged the front right tire—a bulge popped out. I installed winter tires and bought a couple of new winter tires and mounted them on the rims. I'll put the wheels back on with new winter tires in the fall.
The engine has already covered over 1,000 kilometers since reassembly, and I'm already shifting into fifth gear on sections where I can reach speeds over 80 kilometers per hour.
I had the body welded and painted last year. I don't see any new holes, but the paint is damaged in places and rust is showing through.
cherniy_chack
Postby cherniy_chack » Thu Aug 27, 2026 5:08 pm
I've already driven about 2,500 kilometers since reassembling the engine.
The engine's break-in period is complete—the engine temperature dropped while driving at speeds of up to 100 kilometers per hour.
When installing the gearbox, I probably installed the clutch fork incorrectly, and on Monday, something clicked in the car and the clutch lost power.
I tightened the nut and drove off, but soon the clutch lost power again.
On Tuesday, I bought a new clutch cable and replaced it.
Although the old one was undamaged. Now, it seems I've installed the clutch fork correctly—the nut on the cable has changed position.
The clutch works smoothly.
cherniy_chack
Postby cherniy_chack » Thu Aug 27, 2026 6:12 pm
With this key I was able to unscrew the internal pressure regulator valve of the Bosch high-pressure fuel pump.
cherniy_chack
Postby Peterr » Thu Aug 27, 2026 6:18 pm
I can’t figure out how its used….
Peterr
Postby cherniy_chack » Mon Aug 31, 2026 5:10 pm
Over the weekend I cut out the damaged sections of the floor and made repair inserts.
cherniy_chack
