Mk4 FDS in Fuse Box
Re: Mk4 FDS in Fuse Box
Postby legend » Wed Feb 01, 2023 9:59 pm
MinorMatt wrote:P1178 means the cambelt is incorrectly timed. (i.e. the timing of the injection pump is outside the expected range compared with the the crank position sensor)
If its "close" then a jump from power to over-run could well be whats throwing it out
It was opened up again to check the cambelt timing and all was spot on. (pegs in holes etc). So that's a second garage that has checked it.
Is there any timing adjustment within the Lucas EPIC pump itself?
It's just so strange that it runs and starts so well except from hot.
I don't quite understand what you mean - If its "close" ?
Thanks for your comments
Home is where you park it !
2000 Ford Transit 2.5 turbo diesel motorhome. On a LCY190 chassis.
legend
Postby Chug » Wed Feb 01, 2023 11:18 pm
sluggish when warm, ok when cold, could be the starter motor has seen better days.
Chug
Postby legend » Wed Sep 16, 2026 8:52 pm
My van stills nuns and drives very smooth with no loss of power but ...
I've never got to the bottom of my red light coming on when the revs go below 1000rpm and staying on for the rest of the journey.
My Tesco delivery man today turned out to be a 'transit' fan and owner.
He mentioned a fuel pressure switch on the fuel rail that might be faulty.
Does anyone agree?
And is it a simple job?
The NOCO GBX75 BOOSTER that I now always have with me has never failed to start it, so I never need to worry about getting 'stuck' on a garage forecourt.
It's just strange how it is so sluggish to turn over and fail to start if I try to restart it shortly after the red warning light has been on. So the booster fixes that problem.
But if it is a little time (5-10 minutes) after I have turned the engine off it will re-start OK.
Strange!
legend
