Stubborn Screws
Stubborn Screws
Postby d4funky1 » Tue May 09, 2006 7:35 pm
Hi,
The rear bumper of my van has been sawn off and i am trying to remove the screws underneath to place the new bumper on.
Considering this van is 15 years old it's proving to be a little on the stubborn side.
Can anyone recommend a method that will get these off?
Many Thanks
D4
M Reg FORD TRANSIT 100, SWB, Diesel, Manual, Low Roof, 2.5, Non Turbo
d4funky1
Postby MrMPuk » Tue May 09, 2006 7:37 pm
Screws or bolts?
If they are screws try an impact driver like this.
Postby d4funky1 » Tue May 09, 2006 7:38 pm
sorry, bolts
:oops:
d4funky1
Postby MrMPuk » Tue May 09, 2006 7:39 pm
Is it nuts and bolts or bolt's into threaded holes?
Postby Luke » Tue May 09, 2006 7:41 pm
Can of penitrating oil - Plus Gas is the best! spray some on and work the nuts bolts backwards and forwards untill they come loose :D
or just shear them off - they arnt tapped into the body but you will of course need new bolts!!! :D
Postby d4funky1 » Tue May 09, 2006 7:44 pm
d4funky1
Postby Luke » Tue May 09, 2006 7:46 pm
MrMPuk wrote:Is it nuts and bolts or bolt's into threaded holes?
rear bumper mike 15yrs old you work it out :wink: :lol:
Postby Luke » Tue May 09, 2006 7:47 pm
yep thats the stuff - it aint the cheepest but its damn good!!! :D
Postby motorwise » Tue May 09, 2006 7:49 pm
get some heat on it - never fails
http://www.motorwise.net
motorwise
Postby MrMPuk » Tue May 09, 2006 7:57 pm
You never know mate! I'd rather ask the questions and get all the info rather than just say shear them off. If I hadn't asked the first question we'd still be trying to undo screws!
Postby easylife » Tue May 09, 2006 10:31 pm
nut splitter or angle grinder just done mine had one off those ram raider type ones on
easylife
Postby Transitwalla » Wed May 10, 2006 9:18 am
D4Funky1 wrote; Considering this van is 15 years old it's proving to be a little on the stubborn side.
You sound :o its all dependant on the quality of the fixings used...I've seen nuts/bolts rusted solid a year after they've been fitted :(
Nylocs seem to be the best as the nylon inserts help keep moisture out.
As for freeing them off . . . a liberal coating of penetration oil or Diesel works for me.
Imagination....our only limit....
there's no such thing as a daft question.
Jim.
Transitwalla
