alternator problem
alternator problem
Postby doktora » Thu Dec 10, 2009 7:31 pm
hi guys.
today I had my alternator repaired,the brushes were changed,
but when i start the engine there is no battery lamp on dash board,could you tell me what could be the problem,
the van is banana engine'99 non-turbo.
where should i check i assume i forget something while replacing the altrenator
doktora
Re: alternator problem
Postby dodgy01 » Thu Dec 10, 2009 7:58 pm
check all the wires are connected
there are usually 3
dodgy01
Postby Timbo » Thu Dec 10, 2009 10:10 pm
Disconnect the thin blue wire at the alternator and connect it to earth. Switch the ignition on and the battery (ign.) warning light on the dash should be on. If it is then it is a problem with the alternator (maybe new brushes not touching sliprings). If battery light does not come on then it must be bulb or wiring trouble.
Timbo
Postby johnsgotwood » Thu Dec 10, 2009 11:54 pm
I've just gone through this same problem and had 4 different alternators on the van. I didn't actually find an obvious fault with the wiring but I did find that the wires coming out from the main loom were slightly bent. Since straightening them everythings been ok but I did have 3 dead alternators and one of then was a "recon". Don't take it for granted that because the alternators been repaired, its working. Having it tested off the van is sure way to find out and that will also prove where you should be looking. Remember though if your light doesn't come on your battery won't be charging and it won't take long before it will let you down.
johnsgotwood
