Engine and Gearbox Change Help
Postby weldershaun » Mon Jan 25, 2010 10:40 pm
Hi all I have had to change the engine in my high cube banana engined Transit all was going well to I tried to connected the Speedo to the gearbox,
It was then I found out that the gearbox that I have put in has an electronic drive and not the cable drive that I had before.
Is there any way round this problem as the engine and gearbox are running fine and I do not want to remove them if I can solve the matter in some other way
Thanks Shaun.
:oops: :oops: :oops: :oops: :oops:
weldershaun
Re: Engine and Gearbox Change Help
Postby AndyG » Tue Jan 26, 2010 12:26 am
You should be able to swap out the sender with your old one :wink:
Postby SCARBBY » Tue Jan 26, 2010 8:13 am
yes thats right.Just done mine.
SCARBBY
Postby weldershaun » Tue Jan 26, 2010 10:28 am
Thanks lads i will give it a go tonight :D :D :D
weldershaun
