bosch pump sprung a leak
Postby horse » Thu Feb 11, 2010 9:41 pm
lost all power other day pulled up and discovered under bonnet everything covered in diesel :cry: the bosch pump at its lowest point has a plate held on by two bolts, one bolt had dissapeared , i assume rattled out, and the other bolt was bent by some kind of piston behind plate striking plate , this where all the diesel was spewing out of , am i right in assuming this plate covers the actual diesel pump itself ? there was a o ring attached to plate which had split, and to get me home i sourced a similar size o ring and bolt, bit of cranking and it went , phew !
a pump on a friends transit similar year has four bolts over the pump ?
well it went again today, i think the rubber o seal i put in before was nipped in housing, my fault, but it was cold damp and miserable at first attempt and 30 mile from home :(
does anyone know what is behind this plate please ? and any help
heres a pic but not quite clear from a phone camera thanks ...
horse
Re: bosch pump sprung a leak
Postby MinorMatt » Thu Feb 11, 2010 9:59 pm
I cant tell you what is behind the plate, but from memory the O ring has a square profile
Postby horse » Thu Feb 11, 2010 10:12 pm
yes thanks i found the old seal [damaged] and as you say it had a square profile, ive put a round profile seal in it, till i get a proper one from ford or a diesel specialist, i hope this one holds up for now, done 100 mile in it today but want it right asap . wonder what that piston thing is ?
horse
Postby 67transit » Thu Feb 11, 2010 10:47 pm
I had same ploblem,took the metal plate and seal to bosch specialist matched up new seal 99P SORTED :D
67transit
Postby horse » Thu Feb 11, 2010 10:49 pm
99p sounds my sort of figure :lol:
horse
Postby MinorMatt » Thu Feb 11, 2010 11:04 pm
I was given mine by the local diesel place
Postby horse » Thu Feb 11, 2010 11:07 pm
found this link on here :)
viewtopic.php?f=31&t=13187
horse
