mk4 with bit rust
mk4 with bit rust
Postby t.j » Fri Feb 19, 2010 3:50 pm
Hi guys just got this mk4 it is a recovery truck but it as bit rust on the cab mostly the rear section of the cab where it meets the chassi rails. Any one had any experince with this? as I am worried about reinforcement? And help would be great
Regards Dan
t.j
Re: mk4 with bit rust
Postby bortaf » Fri Feb 19, 2010 11:55 pm
On the actual back panel?
had it on all of mine and further up where the window panel meets the rear panel, can make the panel drum or vibrate like a fooker, drove me mad :lol:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby MIXA » Sat Feb 20, 2010 4:57 pm
Best is to chop out the rot and replace with new metal make plates larger than required seam weld and also drill and weld close to cut out area will give repair and added strenght from the extended plate
MIXA
Postby t.j » Sat Feb 20, 2010 5:55 pm
what sort thickness do you think on that 2mm?
Dan
t.j
Postby slogger » Sat Feb 20, 2010 11:32 pm
If your near or in newcastle i have a nice mig welder you can use pay for the lecky and wire and your in
slogger
