Differential on 150 Custom SWB
Postby Bago » Sat Feb 27, 2010 5:08 pm
Hi,
I hope someone can help. I have a SWB 150 turbo custom MK 5 and the back plate rotted through on the diff and let all the diff oil out whilst I was on the motor way. I stopped, fixed the hole with JB weld and topped it up but it still whines alot, worse when it's loaded up. It's a six stud wheel PCD. Should I change the ring and pinion in the diff? If so, which one do I need to get? My friend is breaking a MWB hightop 190. Would this diff be OK?
My axle is a 51a Heavy Sailsbury (Less LSD)
Thanks for your time.
Ian
Mark 5 Smiley 150S (3.2 ton) Turbo SWB low roof Custom with BullBars, hotscreen, rpm counter, power windows, power mirrors, tailgate, cd, ABS brakes, captains chair, cup holder and near mint cond.
Bago
