hey i am trying to change the fuel lines from the filter housing to the injector pump and from lifter pump to the fuel filter
they are the screw on kind but after i loosen and remove the threaded nut (SLIDE IT DOWN THE PIPE) THE TUBE DOESNT REALY COME OUT it spins around but when i pull it doesnt come out
ford dealer told me they should come out after you loose the nuts
any suggestion
also is the lifter pump an item that either work or doesnt at all . i have problem that when i fill the fuel filter with fuel and bleed the injectors i will start but then it dies and the fuel filter is empty . when i cranked teh engine without the fuel filter there was some fuel coming but i dont know if its from the return line maybe i coudnt really see that ?
many thanks i am stucked in Paris ( i love it here ) but now its time to go
does anyone can recomend cheap online source of the fuel lines as the dealer quoted me over 200 euro for the four of them between the lifter pump and fuel injection pump
thanks kamil
