little help peep
little help peep
Postby daveandgina » Sun Feb 28, 2010 12:51 am
hi all little help please, first thing in the morn my 1996 ford transit minibus she fires up and runs for a few secs then dies on me but when i run her and move her shes is fine also pulling off for the first time she shudder off for a few secs but after a mile or two she is fine alway happens every morn any answers welcome.
also any of you know what bodykit will fit her cant find a transit bodykit anywere,
cheers dave
daveandgina
Re: little help peep
Postby AndyG » Sun Feb 28, 2010 4:30 pm
Are you running on diesel :?:
:idea: Try a new filter/service :)
Postby daveandgina » Mon Mar 01, 2010 12:10 pm
hi there sorry forgot to say its diesel
daveandgina
Postby MrCoffee » Mon Mar 01, 2010 12:41 pm
Yep, I'd say its in need of a new fuel filter. I get the same juddering on one of my vans which I put down to moisture on the clutch plate. Always clears up after a while, but does it every morning.
Some people are like slinkies- Not really good for anything, but somehow they still bring a smile to your face when you push them down a flight of stairs :D
MrCoffee
Postby alanwh » Mon Mar 01, 2010 12:48 pm
Air in the system causing a stall and then a misfire :?: First thing to check is the condition of the leak off pipes. lengths of small bore cotton braided pipe that run from each injector. if they are split at the ends and leaking diesel replace them and at the same time do the leak off mod. (try a search) which involves swapping the return to tank pipe from 4th to first injector.
If all ok try a filter change, ensuring the filter is sealing properly on the filter head.
Let us know how it is after this.
alanwh
Postby daveandgina » Mon Mar 01, 2010 10:10 pm
cheers guys will give it a go tomorrow an will let you know how it go's
daveandgina
