Electrical faults in P reg 190
Re: Electrical faults in P reg 190
Postby MinorMatt » Thu Dec 17, 2009 9:09 am
the cold start device is internal within the pump, and all it does is advance the timing.
The bit with the arrow controls the mid range fuelling.
Have you tried cracking off the injectors to make sure diesel is coming out? The other thing is that it could be pulling in air somewhere (possily around the diesel filter) making it a nightmare to start
Postby bdcs » Thu Dec 17, 2009 3:39 pm
The rear lights and dash lights thing happened on mine and eventually turned out to be the connector on the back of the light / wiper stalk. One of the spades in the plug was slack and was cured by putting a small blob of solder on the switch side
bdcs
Postby tranny mhan » Sat Dec 19, 2009 8:34 pm
MinorMatt wrote:the cold start device is internal within the pump, and all it does is advance the timing.
That is where I am going to look next Matt...one question though would just a 2-3 second spray of easy start be enough to get the engine going properly without any lumpiness as the fuel was drawn up from the tank?
tranny mhan
Postby tranny mhan » Sat Dec 19, 2009 8:35 pm
bdcs wrote:The rear lights and dash lights thing happened on mine and eventually turned out to be the connector on the back of the light / wiper stalk. One of the spades in the plug was slack and was cured by putting a small blob of solder on the switch side
I have fixed this problem by bending the switch pins to get a better connection within the connector and all is fine now in that respect..TY for your input.
TM
tranny mhan
Postby ake » Sun Dec 20, 2009 11:16 pm
Have you checked the pump timing yet :?: cos my moneys on that being your starting problem
Postby tranny mhan » Thu Mar 04, 2010 5:53 pm
ake wrote:Have you checked the pump timing yet :?: cos my moneys on that being your starting problem
Not yet but I have a new cambelt to be fitted this week...I will fit that then post back on this thread if that turns out to be what the problem is..
TY for the input Ake its appreciated..
tranny mhan
