judder coming from the back
Postby harrier » Wed Feb 03, 2010 9:53 pm
my van started juddering this morning at around 35mph , pulled over to check wheel nuts were tight , all ok there, then it went , then it come back , past few weeks its been juddering under clutch control when pulling off , any ideas ? diff , prop bearing ? the van is a swb 2000 (w)
thanks paul
harrier
Re: judder coming from the back
Postby bishbasbosh » Mon Feb 22, 2010 5:12 am
i am getting this also its getting anoying now as am unable to find the problem. i have a ford transit 120 t plate ex bt van 2.5di it runs fine but on the road sometimes i feel a shudder that seems to come from the rear almost as if im towing something behind me.
has anyone had this problem before ?
bishbasbosh
Postby SCARBBY » Mon Feb 22, 2010 8:34 am
If it was me I would check the prop bearings especially if you can smell a burning rubbery smell.Try lifting up the back axle and spinning the wheels to see if maybe one tyre has gone out of shape.Ive had this before.
SCARBBY
Postby matthew2riches » Mon Feb 22, 2010 9:51 am
I get it on a cold and damp morning. I just assume it was a little bit of clutch slip and haven't worried.
After a few minutes of pulling off and stopping around our horrendous streets - it stops :D
matthew2riches
Postby jay » Mon Feb 22, 2010 10:19 am
@harrier check the tyres for bulges especially the inside edge...or get the wheel balanced as that will show up any buckles or bulges much easier..
@matthew more than likely wheel spin on inside wheel when going round corners
mk1 connect tourneo
jay
Postby bishbasbosh » Tue Feb 23, 2010 6:45 pm
looking like prop shaft bearing on mine thanks for the advice :)
bishbasbosh
Postby AlanN » Tue Feb 23, 2010 6:55 pm
Prop bearing and/or oil on clutch plate
Postby bishbasbosh » Thu Mar 04, 2010 7:21 pm
just an update on mine prop shaft bearing was gone so got that done but problem was still there when van was loaded turns out one of my leaf springs was snapped aswell :( cant imagine how but all sorted now :)
bishbasbosh
