rear axle on c reg transit
Re: rear axle on c reg transit
Postby tom_moran » Sat Feb 27, 2010 8:42 pm
will do, got some blue gasket stuff here to use. Dont suppose anyone knows what 'should' fit that drain plug? All i know is its square and none of my ratchets fit it :)
tom_moran
Postby AlanN » Sun Feb 28, 2010 12:50 am
Remember to clean out the bottom the of the diff casing, as that is where all the swarf collects, dirty job, but somebody has got to do it :lol:
Postby tom_moran » Mon Mar 01, 2010 6:55 pm
job done!
Only had a couple of issues today, one of the half shafts was seized in, i bent a crowbar getting it loose but it was fine once out. And lastly that drain plug, i ended up getting my small 1/2 inch extension and found a top bloke at checkpoint tyres who let me use his bench grinder for free and i took a mm or so off each side then it fit!. Once id done that it was an hour to get the old diff out, clean the casing, new diff in, all together and done up, thing drives very nicely now.
Once again guys thankyou for your help
tom_moran
Postby madmark » Mon Mar 01, 2010 6:56 pm
8) well done mate :wink:
Postby AlanN » Mon Mar 01, 2010 9:15 pm
Nice that youve posted up after, well done :D
Postby tom_moran » Thu Mar 11, 2010 6:38 pm
cheers alan, ive always tried to post up a result, us men hate unfinished things!
tom
tom_moran
Postby AlanN » Thu Mar 11, 2010 8:33 pm
What ratio have put in, a better one or the same?
