MK5 Heater
MK5 Heater
Postby yrocker » Sun Mar 14, 2010 12:25 pm
Just to check that I am correct in my thinking.
My heater fan does not run, even on position 3.
I have checked with a meter and I have 12volts at the fan connector.
Does this point to a knackered fan?
Any comments would be appreciated.
Mk5 LWB Hitop ex-BT 2.5D now converted to turbo intercooler.
Interior now 2 berth camper with fridge, toilet and warm air heating.
Usually to be seen towing my 1963 Anglia on a trailer.
Len
yrocker
Re: MK5 Heater
Postby MinorMatt » Sun Mar 14, 2010 12:28 pm
Yes
Its a bit of a fiddle to get it out but you can do it without removing the whole dash...
Re: MK5 Heater
Postby yrocker » Sun Mar 14, 2010 12:47 pm
Thanks for that.
Do I remove it towards the drivers side?
Len
yrocker
Re: MK5 Heater
Postby MinorMatt » Sun Mar 14, 2010 1:14 pm
its sort of a bayonnet fit, there is a little tag at about 4 oclock (bulkhead side) that you pull back and twist the motor out.
You can then manouver it out of the radio slot (if you have the large radio, otherwise you have to take the black plastic off...
Re: MK5 Heater
Postby yrocker » Sun Mar 14, 2010 3:57 pm
Thanks. I'll have a look during the week.
Len
yrocker
