K&N air filter mk5
K&N air filter mk5
Postby mat campbell » Thu Mar 25, 2010 2:13 pm
I see k & N do an airfilter for the mk5.
Its £45 and they boast HP increase and better fuel economy.
Has anyone got any thoughts on this??
mat campbell
Re: K&N air filter mk5
Postby barabas » Thu Mar 25, 2010 3:12 pm
I'd be surprised if it did anything for power or economy, it would definately be noisier though... Just a bloody expensive air filter..
The two most common elements in the universe are hydrogen and stupidity.
barabas
Postby sprofan » Thu Mar 25, 2010 6:42 pm
hi, as far as i know they sometimes boast but i would not think on you will notice much diffrence on a transit, the only good thing is i think they have a long life to them as you can clean them and use it again and again but not sure can anyone back me up on this.
sprofan
Postby WildGoose » Thu Mar 25, 2010 7:30 pm
Air flow isn't the limiting factor on a transit, there is still only so much air you can suck in without getting a turbo to help cram it in there.
Won't give any more power. If you notice an improvement, or better fuel economy when you change to a K&N in a transit, then it is probably because your old air filter was dirty.
K&N are supposed to be lifetime filters, but you still have to buy the cleaning fluid or whatever it is, and when transit air filters cost peanuts, i'm doubtful you would make a saving.
To me personally its more faffing about having to clean a filter, than simply buying a new one and binning the old.
WildGoose
Postby Jim Archer » Thu Mar 25, 2010 8:56 pm
As above, doubt you'd tell much difference over a new stock/cheapie filter, but you would over time as K+N's don't clog up like a paper one will, 'specially if you live somewhere dusty or damp.
Whether it 's worth the extra dosh or not is debatable, depends on how often you service it I guess.
With bikes I normally just knock the big bits out and put them back in unless they are badly discoloured, so I guess you could end up saving by not having to buy filters every time.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby darkbluevanman » Fri Mar 26, 2010 3:14 pm
K&N's are the worst at filtering dirt out....
darkbluevanman
Postby dirtydog » Fri Mar 26, 2010 5:41 pm
I'm not completely up on all my van stuff and most of my thoughts are on bike related bits so here's my thoughts
I've had a K&N filter on one of my bikes before (bare in mind K&N boasted more power and better economy for this one as well). As I was modding the bike at the time it had a few dyno runs and it actually made less power with the K&N than it did with the restrictive standard one!
I also had a K&N filter in my Focus ST170 but ditched that in favour of a Pipercross induction kit as I just don't rate the K&N stuff anymore.
I would personally just replace the filter with one from a motorfactors as they aren't that expensive
dirtydog
Users browsing this forum: maitste
