Spares for 92 Transits..Where do I go??
Postby asquith » Fri Jun 30, 2006 2:15 pm
Hello to All
I am new to this and I am looking for quite a few spare parts for 3 mk1 transits. I have a list and chassis numbers for two of them the third is a 190 and I am desperate for front brake pipes and hoses. I only have a pic and rough measurements for these. The spares are for a disabled friend who has found a new interest in old transits. Could someone help/point me in right direction please
Mike
asquith
Postby 100ps_drw_hicube » Fri Jun 30, 2006 3:03 pm
mk1??? 1992???? 92 is a mk4 mate :wink: mk1 is from 65 to 70's :oops: :oops: also if you post in the parts wanted :wink: :)
100ps_drw_hicube
Transit Abuser!!
Postby asquith » Sat Jul 01, 2006 10:39 am
Thanks.... told you I was new to this
As per your advice I post what I am looking for and the chassis numbers they relate to...once again thanks
Mike
SFACXXBDVCMY 72700
SFACXXBDVCKK 62948
ENGINE TIMING BELT & BELT TENSIONER X 2
CLUTCH DISK & COVER, CLUTCH DISK THRUST BEARING X 2
PROP SHAFT UNIVERSAL JOINT & PROP SHAFT CENTER BEARING X 2
PIPE BETWEEN FUEL FILLER AND TANK X 1
FRONT BRAKE PIPES AND HOSES X 1
asquith
Postby TRANSITBILL » Sun Jul 02, 2006 4:03 am
Asquith what 100 means is on the home page if you scroll down theres a advertising section on the left of the page :lol: ,parts wanted in here is where you post for the bits you want :lol: , hope this helps regards Transitbill :lol:
TRANSITBILL
Postby transitgeoff » Tue Jul 04, 2006 7:53 pm
these are 17 digit chassie numbers and not mk1, i think you need to put the year or reg numbers putting asterix as the numbered part of the plate, then we can help you :D
transitgeoff
Postby Neil » Tue Jul 04, 2006 10:55 pm
drive down high street look for a building with a big sign on it FORD go inside and ask for parts depot
Neil v6
Neil
Postby 100ps_drw_hicube » Tue Jul 04, 2006 11:08 pm
Neil wrote:drive down high street look for a building with a big sign on it FORD go inside and ask for parts depot
youll be lucky i struggle to get mk 5 parts let alone mk4 :shock: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby FredTransit » Wed Jul 05, 2006 8:12 am
I don't have too much trouble with the Mk2, most of the running gear is Mk3 anyway. Lots of the brake and steering bits are available as generic parts from most motor factors, ie Lucas for electrics like alternators and Lockheed for brakes.
FredTransit
Mk2 Trannyist
Postby jay » Wed Jul 05, 2006 8:36 am
SFACXXBDVC part of the chassis plate is the same as one ofmine which is mk3.dunno if anyone has the same ???
mk1 connect tourneo
jay
Postby 100ps_drw_hicube » Wed Jul 05, 2006 5:25 pm
ye true!! im talking about specific bits like mk5 seats wheel arches etc etc :roll:
100ps_drw_hicube
Transit Abuser!!
