Brake Pads
Brake Pads
Postby Andy AC » Fri Jul 07, 2006 7:19 pm
Hello guys, how easy is it to change the front pads on a '99 SWB 120? or is it worth getting a rapid fit type place to do it & how much do you think they would charge?
Andy AC
Postby 100ps_drw_hicube » Fri Jul 07, 2006 7:33 pm
easy peasy 30 mins tops get a haynes manual just to make sure you know where everything is :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Brake pads
Postby Andy AC » Mon Jul 10, 2006 9:00 am
I ended up doing it myself, couldn't believe how easy it actually was. I'll have to do it again soon as the discs are nearly knackered.
Andy AC
Postby 100ps_drw_hicube » Mon Jul 10, 2006 9:06 am
good good told ya it was easy sometimes you get the bolt that holds the caliper down it can seize and be a bit of a pig to remove but 99% of time there an easy job 8) 8) 8)
100ps_drw_hicube
Transit Abuser!!
