My fuel guage waves a bit..I don't have a handbrake light, and the side lights put the front fog light bulb on. The MAJOR problem is that the low fuel light has the arrow pointing to the wrong side! That will be confusing!
Oh, and the speedo is more accurate.
I bought another clock today from a P reg mk2 mondeo turbo diesel. The revs counter was reading wrong so I swapped it with the 1 from my other clock and now it all works perfect. When the fuel light comes on it does have the arrow pointing the wrong way, so you just unclip the front off the clocks and swap the black surround on the botton right hand corner which has the fuel light and a couple of other symbols on as well. The only real difference between my new and old clock is the new 1 has a resisitor board fitted to it in the middle at the bottom on the rear of the clock. The old clock didnt have that or the connections for it. Otherwise its identical to the old clocks I posted pitures of on the 1st page of this thread.
