I've got a lwb semi hightop minibus, not had it for long and recently the power has dropped massively
I'm not a mechanic but I am having to learn quite alot lol, luckily my brother is a mechanic
I noticed one of the injectors had a loose cap and diesel was leaking out of it. Got my brother round and he said that there must have been a problem with this injector as at some point and someone had put ptfe tape at the bottom of the injector. Also the reason the cap has come loose is because presumably the last owner knackered the thread when screwing it back on.
The van is knocking on a bit now (w reg but still an awesome van) and I wondered whether it would be better to replace all the injectors rather than just the knackered one?
If I do replace them what should I go for and where is the best place to get them?
If it helps the vans reg is W549XKM
Thanks in advance for any help
