correct wheel/tyre sizes for my mk 5
Postby oldmadbiker » Wed Oct 28, 2009 8:01 pm
hi all.my mk 5 has 185/14 tyres fitted to 5 stud ford alloys.
ive been told the mk 5 should have 15 inch rims.is that so cos i was thinking of
fitting bigger to get better gearing.
also while im here any one want to swap my 4 alloys,one with a brand new tyre for a set
of steel 15 inch.
would 16 inch fit.
thanks in advance for any help.
oldmadbiker
Re: correct wheel/tyre sizes for my mk 5
Postby Altransit » Wed Oct 28, 2009 8:04 pm
The correct size wheel for a mk5 5 stud is 14" :wink:
:idea: You could increase the rolling radius by fitting 195 section tyres on :mrgreen:
Postby oldmadbiker » Wed Oct 28, 2009 8:37 pm
would that make much of a differance to the gearing.seems
at too high revs at 60.
oldmadbiker
Postby geminivehicles » Wed Oct 28, 2009 9:14 pm
if you get stuck ill do you a deal with a set 14" steel wheels
1999 100 MK5 LWB CUSTOM SHR aux batt,e/w,c/l,tv,dvd,xbox,cctv
transit mk5 custom with a evil twist (painted at last)
geminivehicles
Postby oldmadbiker » Thu Oct 29, 2009 12:49 am
will i be able to get a set of 15 inch too fit ok with 195 tyres.
oldmadbiker
Postby alanmercman » Thu Oct 29, 2009 12:52 am
i believe u need to change the back axel and diff to get better gearing .ie lower rpm,and more speed.the infos on here somware try search for "axel ratios " :D
alanmercman
Postby alexgrfc » Thu Oct 29, 2009 11:21 am
6 stud axle's are 15 inch
Transit t260 100
**********visit my blog @ http://www.transitpics.co.uk// **********
http://www.scottish-vanners.co.uk
alexgrfc
Postby MinorMatt » Thu Oct 29, 2009 10:02 pm
and there are some 15" mk5 5 stud alloys but they are rare
Postby MrMPuk » Thu Oct 29, 2009 10:14 pm
MinorMatt wrote:and there are some 15" mk5 5 stud alloys but they are rare
There's a set in the for sale section infact. :wink:
Postby djdrew123 » Mon Nov 02, 2009 9:13 pm
i seem to have 16" wheels on my p reg transit 190 lwb :-S
djdrew123
Postby Altransit » Mon Nov 02, 2009 11:55 pm
djdrew123 wrote:i seem to have 16" wheels on my p reg transit 190 lwb :-S
Are you measuring them across the rim lips :?:
What size tyres are on it?
Postby djdrew123 » Tue Nov 03, 2009 12:48 am
i measure from one side of the metal wheel to the other inside lip and not sure bout tyres never checked yet
djdrew123
Postby MrMPuk » Tue Nov 03, 2009 4:37 pm
djdrew123 wrote:i measure from one side of the metal wheel to the other inside lip and not sure bout tyres never checked yet
You've got 15s then. :wink:
Postby scatchmo » Mon Jan 18, 2010 11:49 am
Mine is a 1999 Transit 100 with 195 R 14 inch 5 stud your getting me worried!
Who is right here?
Scatchmo, St Athan, South Wales
scatchmo
Postby MinorMatt » Mon Jan 18, 2010 12:06 pm
right
91-00 transits have 14" wheels if they have 5 stud axles (models 80, 100, 120), these can be fitted with 195/14C or 185/14C depending on model/age. If it is fitted with 6 stud axles then it will have 15" wheels fitted with 225/70/15C (Models 150, 190). I think some tourneos (also 5 stud) were fitted with 205/14 tyres.
There are also 15" alloys avaliable to suit vans with 5 stud axles - but these are very rare.
Twin wheelers are slightly different, I believe that up to '94 they were fitted with 14" wheels and '94-00 15" wheels.
Hope that clears it up?
