Panel replacement work underway !
Postby fmr » Tue Jul 24, 2007 9:53 pm
First photo shows plate welded to floor and undersealed.
Second photo shows plated inner-wing again undersealed.
New cross-member section welded in place. Viewed from the rear.
Viewed from the front.
Cross-member welded to the inner-wing.
L shaped profile being used to replace wheel arch lip.
Profile ground so it will bend around the wheel arch.
Wheel arch lip held in place with clamps.
Wheel arch lip welded in place.
Rear quarter panel nearly welded in place. Are there enough spot welds ? Shouldn't fall off !
Well there you go guys one side is nearly done. What a challenge !
Phil
Was buying this van a good idea ? It's looking good !
fmr
Postby Retrohowla » Tue Jul 24, 2007 10:00 pm
Good stuff, you wanna come do mine for me? :wink:
If you own a transit, learn to weld
Retrohowla
Postby Retrohowla » Tue Jul 24, 2007 10:08 pm
fmr wrote:
One thing I have noticed, I am using a hobby mig welder. The disposable gas bottles don't seam to last very long :cry: The first bottle I used was CO2/Argon mix the second was just CO2, I didn't notice a lot of differance between the two. I was told that the Argon mix would weld 'cooler' and reduce 'blowing through' :
I use argon/co2 5% it is better than co2 alone and when you get the proper stuff you do see the difference, dont know if you noticed but i have a large bottle i get from an industrial welding supplier, works out the same price as three small bottles for one fill and a months rental and lasts longer than you could hope for :D :D :D
Retrohowla
Postby fmr » Wed Jul 25, 2007 7:03 pm
Quick word of advice to all forumites after spending one and a half hours in my local A & E hospital department:
Always wear eye protection when using an angle grinder:idea:
I thought I would be clever and get away with it :wink: I should know a little better it has happened before :shock:
Phil
fmr
Postby rover » Wed Jul 25, 2007 7:38 pm
They get you sorted out? No serious damage I hope?
Rover.
rover
Postby fmr » Wed Jul 25, 2007 7:48 pm
Thanks rover, no serious damage should all be good as new in a couple of days.
As I said I just feel a little stupid as I have had this happen before :oops: I wear glasses anyway and you think these alone will offer a little protection but clearly not.
Phil
fmr
Postby dangeeeeerousss » Wed Jul 25, 2007 9:41 pm
hi sorry to hear about the eye
thats another feeling i know well
it could of been worse you could of had arc eye as well as that :lol: :lol:
dangeeeeerousss
Re: Panel replacement work underway !
Postby vana mana » Fri Feb 26, 2010 1:19 pm
i been at Luton & dunstable hospital with metal in me eyes more times than i can remember...BELIEVE WEAR EYE PROTECTION IF MESSING ABOUT WITH ANGLE GRINDERS & METAL !!!!
Ear plugs are handy too...
vana mana
Re:
Postby mountainpike » Sat Feb 27, 2010 12:04 am
Guy88 wrote:
fmr wrote:But be warned, the Arc is coming out on the chassis plating :twisted: :twisted:
Phil
MIG it all :wink: :wink:
I second that
mountainpike
Postby AlanN » Sat Feb 27, 2010 1:53 am
Blimey, havent seen this thread for a while :lol: its getting on for 3 yrs old
