Mondeo Dash ...again.
Postby AndyG » Wed Apr 05, 2006 12:22 am
MarkM wrote:
MarkM wrote:
daddy cool wrote:Is it worth asking this lot, won't cost anything, they have an advice forum.
http://www.fordmondeoownersclub.co.uk/
Just a thought... :D
I thought there might be a mondeo owners forum ...but will they actually know the answer as the item is meant to fit in the vehicle they are fans of, afterall they are very unlikely to be fitting a single dial Transit unit to their st24 or whatever, unless you mean the part I want identification of?
Since it is an old style message board I have posted up the question...if it gets an answer we shall see... http://www.fordmondeoownersclub.co.uk/f ... p?mid=2885
Another update...since the diode is now being talked about. The posting of the question on the Mondeo owners club proved as I thought it would be.... a waste of time...still no answer so obviously no-one there knows or actually has any clue when it comes to swapping parts around. But in their defense they are more concerned with switching trim parts around and things breaking/repairing rather than what is in effect is customisation.
The diode 'might' be this part I asked about before...especially since it isn't present on my cluster (still for sale/swap peeps ;) ) Which tends to suggest that the diode on a Mondeo is elsewhere.
Here is the picture of 100ps's cluster with the 'diode'?? pointed at.
Just a :idea: This 'diode' that's being pointed at in 100ps's piccy looks like a stabilizer circuit used on the earlier alternator variants. Not required on the later ones with the more modern alternator :?: Is anyone near Uxbridge :?: give us a pm.
Postby OxtonyxO » Wed Apr 05, 2006 7:04 am
my clocks came from a 98 d lx mondeo
OxtonyxO
Postby MarkM » Wed Apr 05, 2006 2:26 pm
Andyg wrote:
OxtonyxO wrote:so maybe i need a rev counter out of a 92-95 tranny
Sorry mate rev counters are on smileys :arrow: that's late 94 onwards.
I'm trying to crack this for you but it's difficult with the different versions of the same thing :x
Can you tell me if your mondie clocks have seat belt reminder or anything:?:
The set I had (now 100ps's) has the seatbelt warning lamp but no bulb or circuit connection. Ford's must simply use a generic cluster for either the Transit or Mondeo and then apply the plastic circuit depending on which model the cluster is being fitted into.
MarkM
Postby AndyG » Thu Apr 06, 2006 12:41 am
OxtonyxO wrote:my clocks came from a 98 d lx mondeo
I've had a carefull look at the early and later 98 mondeo diesel clock circuit diagram for the rev counter part. It ought to work :!: Are you sure that your oil pressure warning light is working properly :?: Can you disconect it from the switch temporarily just to make sure :?: The reason I'm asking is to ellimenate the fact that the wrong bulb could be lighting up as mondeos have their bulbs in different places.(You'll have to ignore what the symbols are saying)
The reason I'm asking about the oil pressure light (incase you're wondering) is because the feed for the rev counter is on the same rail :wink:
Can you not get a simple volt meter to check that you have 12volts at the rev counter with ignition on :?:
Then with ignition off check that you're rev counter is properly earthed.
If it's not earthed properly, cut the printed circuit for the alleged earth for the rev counter and put your own in using a piece of wire.
The reason I'm telling you to do it this way is we don't want to upset anything that could be sharing this rail.
Best of luck and keep us posted :wink:
Postby OxtonyxO » Thu Apr 06, 2006 6:52 pm
cheers andyg will give that a go after the M.O.T. :cry:
OxtonyxO
Postby OxtonyxO » Sat Apr 08, 2006 9:43 am
ok PASSED mot no problems
just hot wired the rev counter one wire to negative one to positive and one to the alternator feed
when i did this it behaved the same as when in the dash only i had to put gnd to + and b+ to the negative terminal
also tried the oil pressure switch started the engine and removed this cable
but the oil presure light did NOT come on :?:
any ideas
cheers tony
OxtonyxO
Postby AndyG » Sat Apr 08, 2006 11:56 am
Well done on your :D MOT :D . Oil pressure light - I presume this is ok when it's connected :?: and the correct light/icon lights up :?:
Rev counter has now thrown me 'cause the way you wired it up should have worked WITHOUT reversing the + and - cables :?
Now I'm stuck :cry:
Possible faulty rev counter :?: Possibly blown it somehow :?: :cry:
I'm gonna look again for you. I'm now just as determined as you are to get this sorted :wink:
Postby OxtonyxO » Sat Apr 08, 2006 12:03 pm
i have 3 rev counters 1 petrol mondeo 1 diesel mondeo 1 granny v6
both the mondeo counters work the same
the oil presure switch taken it off again and put it to earth then the oil light comes on :oops:
what is the other wire going to the alternator?
do i need to put a resistor in circuit does the transit need one mondeo dont?
where is the rev counter connected on a mondeo?
OxtonyxO
Postby AndyG » Sat Apr 08, 2006 2:42 pm
On the Mondeo, the rev counters take their pulse from the PCM (powertrain control module) not the alternator :!: This doesn't make much sense if others have done this conversion and had no trouble :?
I'm gonna see if I can get my hands on a mondeo rev counter and try it myself :wink: There is something very fishy going on here :o
Postby OxtonyxO » Sat Apr 08, 2006 2:53 pm
yeah mate think your right my rev counter works but the pulse it is getting is wrong. at tickover the rev counter read 7000rpm when it should read 700rpm so i do not see how this will work without a frequency changer maybe the rev counter fitted to a transit has different eletronics
my rev counter is a 98bp hicubes trinsit rev counter is a93bb do we know what the bp and bb mean?
OxtonyxO
Postby AndyG » Sat Apr 08, 2006 3:53 pm
British Petroleum :!: :lol: :lol:
I think the numbers are refering to when the component was manufactered; so 93 and 98 do make sense but don't have a scooby 'bout bp/bb :?:
Postby 100ps_drw_hicube » Sat Apr 08, 2006 3:56 pm
if its any help my mates granny has gg on the speedo :shock: have got a sierra speedo sat here so will look and see what that says :?
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Sat Apr 08, 2006 4:12 pm
Thanks 100ps_drw_hicube :wink:
It's the right day for gg's :lol: :lol:
Postby AndyG » Thu Apr 13, 2006 1:08 am
News:
Got myself a mondeo rev counter and today while fitting my replacement hands free (for my new camera phone) I pulled the dash and plugged in the mondeo rev counter.
YES! it works :D
Had smoke and fuse go on me when I tried the to plug the complete thing in :oops:
Guess you shouldn't plug in a cable driven binacle into an electronic type/version :oops:
Hey :!: What are fuses for :?: :lol:
So my question is does any body want a good working rev counter (clock only) to put into their binacle :?:
Postby OxtonyxO » Thu Apr 13, 2006 5:55 am
did you have to run the cable from the alternator
OxtonyxO
