Immobiliser Bypass on a 2000 MK5
Re: Immobiliser Bypass on a 2000 MK5
Postby robbie.cee » Thu Jun 27, 2013 9:28 am
Next time I can get on my laptop I will be glad to help if no one else furnishes you with the info you need !
Just moved, still manic ere, on my phone right now so its a mission writing anything!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby les burney » Thu Jun 27, 2013 9:52 am
thanks any way , worked it out , - no need to take engine out , or take pump off , leave metal guard alone . access to sub wiring harness before it goes into pump . 30 minutes work , now running , still learning more about the pat,s system . ? .
les burney
Postby FUNCL3JJ » Mon Sep 09, 2024 9:15 am
Hello
I’m having a similar issue.
Van starts and runs well
Then after a few days. Started, ran for 10 min then cut out.
When trying to restart, key lights up dash but doesn’t turn engine over.
Told immobiliser fault.
Left it for a week.
Then started perfectly driving me 300 miles around a route turning off and on as it should.
Few days passed and again it cut out and wouldn’t turn over.
When it cut out, battery light flashed
I know it needs the EGR valve changed
But was told this wouldn’t cause the above problem.
Any help please?
Thank you
FUNCL3JJ
