How to remove the rear floor panel mk5 swb
Re: How to remove the rear floor panel mk5 swb
Postby vanmanloki » Tue Mar 26, 2013 1:18 pm
well not much of one, but some bits of it are still there :?
FORD BUILT TOUGH
1998 Tourneo GLX restoration
viewtopic.php?f=27&t=122620
How to remove a rear floor panel swb mk5
viewtopic.php?f=4&t=127587
vanmanloki
Postby vanmanloki » Tue Mar 26, 2013 1:28 pm
new floor has just arrived, Big thanks to Tim (dieselhead123) for sorting that out for me 8)
i cant wait to get the old one out and start to clean the underneath
FORD BUILT TOUGH
vanmanloki
Postby dieselhead123 » Tue Mar 26, 2013 7:52 pm
Glad it got there safe mate, will be good to see your progress, not fitted one of these myself as yet, probably not long until I do though :roll: , oh the pleasures of Mk5 ownership :lol:
Postby RonTransitmk5 » Tue Mar 26, 2013 9:04 pm
vanmanloki wrote:new floor has just arrived, Big thanks to Tim (dieselhead123) for sorting that out for me 8)
OMG WOW!!!!!
I now so wish I had bought that doing mine :mrgreen: :mrgreen: :mrgreen:
2003 Ford Transit Connect 1.8 TDDI Red.
1999 V reg MK5 Bus(M2) Mid Roof, 2.5di, diamond white. GONE
RonTransitmk5
Postby vanmanloki » Tue Mar 26, 2013 9:13 pm
to be honest, I've never done anything like this before at all, so fingers crossed it all work out :shock:
i hope to get the old floor out tomorrow. So far i have removed the spot welds on the top of the outer rear cross member, and cut each end. the plan is to peel it back just far enough to gain access to the floor, i don't really want to take the whole thing off if i don't have to.
I'll take some pics tomorrow before i go any further. Having the floor there will help a great deal in taking off the old one, cause I'll have a better idea what to look for now, more so with the wheel arches, as i wasn't sure how they were fitted, but now i think i have it figured out :)
pleasures of Mk5 ownership indeed, its an adventure :lol:
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Tue Mar 26, 2013 9:27 pm
OMG WOW!!!!!
hey just think, if either of us had thought of it before hand, we wouldn't of had to spent hrs chipping away all that sound deadening :mrgreen:
but i don't think you have any worries with your floor its solid 8)
FORD BUILT TOUGH
vanmanloki
Postby RonTransitmk5 » Tue Mar 26, 2013 11:42 pm
vanmanloki wrote:
OMG WOW!!!!!
hey just think, if either of us had thought of it before hand, we wouldn't of had to spent hrs chipping away all that sound deadening :mrgreen: :lol: :lol:
RonTransitmk5
Postby RonTransitmk5 » Tue Mar 26, 2013 11:50 pm
I bought mine Jan 2012, & never had even looked under a bonnet before either, of any motor, all my knowledge gained since joining in think Jan 2012, is either self taught or learnt via members on here.
I learnt how to weld via Youtube, lol 100% TRUE
RonTransitmk5
Postby vanmanloki » Wed Mar 27, 2013 9:12 pm
i don't doubt it Ron, you can defo learn a lot with the internet these days. things that at one time you wouldn't even think of attempting, now you can go online, do a little research and feel more comfortable in giving it a go. and with great forums like this, full of fantastic people always willing to help. it makes it easy to give it a go :D
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Wed Mar 27, 2013 9:53 pm
well i started on my floor today, and i'll be honest.....after working on it for a bit i thought.... what have i gotten myself into :shock: only it didn't come out so polite :?
but its not that bad, drilling the spot welds is easy enough, the problem is....finding them. Some of them are dead easy to find....some not so easy. And some just impossible, some leave a mark some don't, and some are covered in rust.....its crazy. so i came to the answer of where i cant find the welds I'll have to cut, trim, grind, what ever it takes to get the old floor out with as little damage done as poss.
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Wed Mar 27, 2013 10:04 pm
i have cut the inner arch neatly, and the edge of the new floor will fit underneath it, and once its welded along where i made the cut, it will be better then new 8)
FORD BUILT TOUGH
vanmanloki
Postby AlanN » Wed Mar 27, 2013 10:15 pm
vanmanloki wrote: only it didn't come out so polite :?
Arh, welcome to my world :shock: :lol:
Postby dieselhead123 » Wed Mar 27, 2013 10:38 pm
You are doing a fine job there.
What type of spot weld drill are you using? The type like a hole saw or the milling cutter, personally, I find the latter best.
I have purchased a stock of these, 6, 7 and 8 mm diameter, I was thinking that now I have tested then for quality, or offering sets of 3, one of each size, to forum members.
Which ever type you are using, get a small pot, like a spray can top, put a bit of engine oil in it and dip the cutter in the oil each cut, they will last longer.
Keep up the good work
Postby vanmanloki » Wed Mar 27, 2013 10:46 pm
Alan, you must have the patience of a saint for the amount of panels your taking off. i'm only part way into one panel, and i have already resorted to hacking parts off with a grinder :lol:
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Wed Mar 27, 2013 10:55 pm
dieselhead123 wrote:You are doing a fine job there.
thanks Tim :)
i'm using the milling cutter type 8mm its been good, cut through like butter.....well that is when i can find the spots
i'll defo get me a cap full of oil, i got 2 bits but the first one is starting to get a little dull, i'll keep the next one oiled :)
FORD BUILT TOUGH
vanmanloki
