Benefits of fitting turbo
Re: Benefits of fitting turbo
Postby nick217 » Sun Dec 08, 2013 6:24 pm
Better got some wd40 on mine then before i get at it.. :roll:
nick217
Postby bobdragon12 » Sun Dec 08, 2013 7:01 pm
It's always the one that won't come out :roll:
MK2 LHD coachbuilt Camper 2.5TDI
bobdragon12
Postby bobdragon12 » Sun Dec 08, 2013 7:03 pm
nick217 wrote:Better got some wd40 on mine then before i get at it.. :roll:
Yep , as soon as I turned the HEX the inside rounded out , I'm going to try and weld a bolt on it next as it would be nice to use the correct hole
bobdragon12
Postby nick217 » Sun Dec 08, 2013 7:16 pm
Also i will be getting the old blow torch out on her too ;)
nick217
Postby Jim Archer » Sun Dec 08, 2013 7:21 pm
Drive a Torx bit into it, that is usually enough to shift it.
Middle one is the cam feed gallery.
Lower one is the coolant drain plug(?) I think.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby bobdragon12 » Sun Dec 08, 2013 7:24 pm
Jim Archer wrote:Drive a Torx bit into it, that is usually enough to shift it.
Jim
Good advice will give that a go before the welder , it's been heated and WD40 to death so it may pop when I go back out in a minute
bobdragon12
Postby Jim Archer » Sun Dec 08, 2013 7:31 pm
It's stuck in there pretty firm with sealer, firm continuous pressure rather than yanking at it seems to work best.
Jim
Jim Archer
Postby bobdragon12 » Sun Dec 08, 2013 8:48 pm
Why is it you always run out of gas just when you need it :? :?
bobdragon12
Postby dave the van » Tue Dec 10, 2013 11:21 pm
just curious as to what turbo you use ??
dave the van
Postby bobdragon12 » Wed Dec 11, 2013 9:47 am
dave the van wrote:just curious as to what turbo you use ??
I found a complete turbo DI transit in my local scrap yard so I had all the corespondent bits , not sure if the turbo is actually any good but it seemed to good for £40 and it solved my clearance issue as I installed a banana engine and as my transits LHD the banana manifold fouls my break master cylinder .
bobdragon12
Postby bobdragon12 » Sun Dec 22, 2013 1:40 pm
Anybody know the thread size of the oil feed on the standard ford turbo ?
bobdragon12
Postby myceliumu3 » Sat Dec 28, 2013 3:04 pm
I suggest you pm Diesel head as he is a mind of information and experience.
Regards
Charles
iI only go to the garage for mot
myceliumu3
Postby darkbluevanman » Sat Dec 28, 2013 9:05 pm
bobdragon12 wrote:Anybody know the thread size of the oil feed on the standard ford turbo ?
I got one off ebay for a fiesta TD, knowing ford most stuffs usually the same, there are some cosworth ones on which are 1/8npt - 1/4bsp male-male, but I think these fit in the turbo, not the block...
darkbluevanman
Postby F111ORY » Sat Dec 28, 2013 10:28 pm
Hi, There are easier ways of getting a turbo oil feed!
F111ORY
Postby bobdragon12 » Sun Dec 29, 2013 4:45 pm
F111ORY wrote:Hi, There are easier ways of getting a turbo oil feed!
Yeh I got all those bits it's just the fitting I have going I tot he turbo is not the same as the pipe I have so was wondering what thread the turbo was
bobdragon12
