meerkatmag wrote:it needed a different connector terminal so that had to be sourced and changed, it was very hard to find the newer Mitsubishi style connector.
MinorMatt wrote:meerkatmag wrote:it needed a different connector terminal so that had to be sourced and changed, it was very hard to find the newer Mitsubishi style connector.
For reference its called a junior timer socket, and is very commonly used and readily available
CamperVanBeethoven wrote:No idea how or where you get the appropriate bits and bobs (including longer belt), but apparently some ambulances had a 'dual alternator' arrangement. That's one possibility ...
