85 or 100ps DI TD
Postby AndyG » Sun Jul 08, 2007 12:01 am
Any colour paint left on the injectors :?:
I reckon it's a 100PS myself :!: :wink:
Postby 4x4 rob » Sun Jul 08, 2007 12:31 am
just had a look doesnt seem to bee any paint left on injectors,is there any way of finding out from the engine number??
4x4 rob
Location: East sussex, 1991 county 4x4 Turbo Di power steering new paint job bmw metalic black
Postby AndyG » Sun Jul 08, 2007 12:38 am
4x4 rob wrote:just had a look doesnt seem to bee any paint left on injectors,is there any way of finding out from the engine number??
I think you can :!:
What is stamped in the block,above the sump flange on the same side as the pump :?: (is where it is on a turbo)
Postby gemini » Sun Jul 08, 2007 12:43 am
should be here on an early engine
gemini
Postby AndyG » Sun Jul 08, 2007 12:48 am
gemini wrote:should be here on an early engine
Including the turbo :?:
So when did the turbos start getting their numbers on the opposite side :?:
Postby gemini » Sun Jul 08, 2007 12:53 am
thats the early Di, the later engines have the numbers on the opposite side, not sure what year from though
edit, i do now
transitgeoff wrote:well it used to be on Transit up to approx 1997, from then on, its on the head right at the front next to the small water pipe that goes to the heater matrix and its on the block not visable from the top without removing the starter :wink:
gemini
Postby 4x4 rob » Sun Jul 08, 2007 1:08 am
I think you can :!:
just had a look the only num i can see is by the oil pressure sender which is 03f91
4x4 rob
Postby 4x4 rob » Sun Jul 08, 2007 1:24 am
does anyone know what the engine code is for the 100 and 85ps engines :?:
4x4 rob
Postby andykay » Sun Jul 08, 2007 1:30 am
1992 MK4 120 SWB V6 24V AUTO
1996 MK5 100 LWB TD AUTO
Don't take life too seriously; you'll never get out of it alive.
andykay
Cosworth Powered
Cosworth Powered
Postby V184 » Sun Jul 08, 2007 11:56 am
This engines fitted with the early type injectors so the 100ps wont fit. You can adjust the fueling screw on the back of the pump and get quite good results !
V184
Postby 4x4 rob » Sun Jul 08, 2007 5:57 pm
andykay wrote:Have a look here http://fordtransit.org/forum/viewtopic.php?t=3787
Andy.
I have found some numbers exhaust side which say 4AE 1871987,which according to Andys link this engine is a 100ps epic, i have a bosh pump and injectors either the pump has been changed :?: but what about the injectors :?: :?: could this be a special build as it was fitted to a J reg ambluance from new here are a few more pics :? :?
4x4 rob
Postby jace » Sun Jul 08, 2007 6:29 pm
thats the engine noah had powering the ark either had older head put on but dont think its everseen a fly bye wire pump! has it got a lift pump under exaust manifold towards back engine?
1x nissan navara hardbodys 1x nissan navara 3.0td kiwi import 2004 2.4 tdi crew cab tipper
jace
Postby MrMPuk » Sun Jul 08, 2007 6:34 pm
4EA is 100ps EPIC Turbo not 4AE which is what you say have!
Postby 4x4 rob » Sun Jul 08, 2007 6:37 pm
no lift pump there is a blanking plate where it would go
4x4 rob
Postby 4x4 rob » Sun Jul 08, 2007 6:41 pm
MrMPuk wrote:4EA is 100ps EPIC Turbo not 4AE which is what you say have!
sorry the first three digits are 4EA my mistake. but what is this engine :?:
4x4 rob
