by dumper » Wed Apr 08, 2026 7:46 am
Back in the day used to do loads of di belts used to lock the flywheel first making sure it was on the correct stroke by the cam and pump pins lining up or very close and maybe needing a wiggle to get them in never had a problem it was only when reading on here years later that there are two holes in the flywheel when fitting the new belt a common mistake people do is not slacking off the four nuts on the pump drive so the gear can turn and not throw the pump timing out when the tension is set then retighten the nuts.
Forget what I said about the valves been closed to determine top dead centre on no 1 as that would have only helped if you were checking the timing before removing the belt .
Unless anyone else on the forum can think of away of of been sure of the correct flywheel hole to use you could remove no 1 injector and use a dti gauge or head off to find top dead centre if you have timed it up wrong the only damage you may have done is bend a pushrod or snap a rocker arm
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
