cherniy_chack wrote:To successfully change the old Lucas to Bosch after 92 years, you need to change the crankshaft and camshaft pulleys for a belt with a tooth height of 3.5 mm.
The Bosch pump pulley with a low 2.5 mm tooth has three fixing bolts, the Bosch pump pulley with a high 3.5 mm tooth has 4 fixing bolts and a different size of the center hole.
Bosch pulleys can be replaced together with a hub pressed onto the pump shaft without a key, so installation errors are possible.
It is very likely that Bosch and Lucas pump hubs are not interchangeable.
I think it is easier to find and replace the crankshaft pulley and camshaft pulley for a high tooth belt.
I did that.
Hello,
My transit is from 1990, 2.5di, LucasPump , will I have to replace the crankshaft and camshaft pulleys to put a Bosh injection pump ?
