advice on Gaskets please
Re: advice on Gaskets please
Postby TM2025 » Thu Oct 09, 2025 10:51 am
gotgcoalman wrote:Seem to remember that cylinder heads were interchangeable between the 1.6 and 2.0 although I think the timing belts were different
So the head gaskets should be the same apart from bore diameter.
List should say 1.6/2.0l.
Sent from my LE2101 using Tapatalk
Thank you so much!
TM2025
Postby TM2025 » Thu Oct 09, 2025 10:52 am
gotgcoalman wrote:Had a quick look on eBay.......
That's ideal thank you again!
Tracey
TM2025
Postby dumper » Thu Oct 09, 2025 2:33 pm
Yes the heads are interchangeable some tuners when porting the head would use a 1600 head on a 2000 to get a better flow rate there thinking being that the ports were too big on the 2.0 L and some turners recommended using the 2.0 L injection head as it has apple shaped ports as I’ve never had a injection head off I don’t know if that is correct.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
