Fuel-Stop Solenoid Valve
Re: Fuel-Stop Solenoid Valve
Postby Peterr » Thu May 28, 2026 6:01 am
The injectors worked fine when the Lucas pump was on. I’ve read elsewhere that when doing the conversion to a Bosch pump I can keep the Lucas Stanadyne pencil injectors. Is this incorrect or are you suggesting that my injectors are not working correctly?
Keep on Transiting !
Peterr
Postby dumper » Thu May 28, 2026 8:46 am
It worked for me when I changed the Bosch to a Lucas pump
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Peterr » Thu May 28, 2026 8:49 am
I’m not moving to a Lucas, I removed it. Put a Bosch instead.
Peterr
I think we’re mixed up here
Peterr
Postby cherniy_chack » Thu Jun 04, 2026 4:42 pm
I looked in the interactive manual in French for the opening pressure of the "thick" injectors for the Bosch and Lucas CAB pumps; they are practically the same: 260 and 250 bar, respectively.
This is for new ones, old ones need to be checked and adjusted as close as possible to the nominal value for the BOSCH pump.
cherniy_chack
