brakes
Postby Nighthawk » Tue Jan 03, 2006 9:07 pm
My guess is water ingress inbetween the mater cylinder and servo units.
Undo the 2 nuts and pull the master cylinder away from the servo, any signs of red rust in there is a problem.
I've seen quite a few where the piston in the master cylinder hasn't returned to rest fully. If this is the problem, you'll see that the piston is 1 to 2mm away from the circlip.
I've seen a few of these get hot enough to melt the wheel nut caps!
BTw, you don't need to touch the brake fluid system to check this, the pipes will allow enough flex to have a wee look inside.
the root cause is a perished O ring seal between the 2 units.
Nighthawk
Postby 24vMk2 » Tue Jan 03, 2006 11:35 pm
I've had something like this happen on my mk3.
It was due to a miss match between the servo and the master :?
Turns out that they is 2 different pin lenghts in the servo, placed two washers behind the master to space it out by 2mm, never had the problem again.
The washer was meant to be a tempory fix, :oops: but they are still there! and the brakes were excellent, even with the V6 in it :D
24vMk2
Rover says
Postby ovlov » Tue Jan 03, 2006 11:42 pm
rover wrote: 90% of the Daewoos' on the road.
Is there realy that many Daewoos on the road but
I supose Lada drivers have to drive something
I want to live forever so far so good
ovlov
Re: Rover says
Postby rover » Wed Jan 04, 2006 12:16 am
LMFAO :lol: I saw one of those yesterday, I was hoping they had all gone by now :shock:
rover
